SWS-SAG Key Not Found Perfect Solution... Hi.. for sws-sag user who are facing Key Not Found..! problem...i've repair with this solution many boxex..also before this solution..i've try many but not get sucess..this work 100%..tested on many boxex.. Step:-1 Just Open ur Box.. Step:-2 Find 4 MHZ crystal near USB Connector.. Step:-3 First resolder the 4 MHZ crystal..and chk again if still Key Not Found..! then step 4 Step:-4 Replace this 4 MHZ crystal with newone ..(not sure but sometime bad connection also cause by this..if i m not wrong.) See this Image's next time i update this with new clear images http://desiw.org/uploads/5af2479304.jpg http://desiw.org/uploads/b83a2b063f.jpg best regards.. |
good work freind, need more good picture ;) u can use scanner to take ur pic :) br <= The_Gorr => |
@ The_gore. yes you are right, but how many cell phone repairer can't find a crystel with it's velue on small pcb with big parts, then cell phone pcb. ? @ muksforu, just want to say . this is realy use ful for all who have this error Key Not Found..! wbr |
this solution don't work, i have changed two quartz. |
i have same problem key not found! i change the crystal but same key not found. help me please . when i try to update key i see updating key ERROR,try again :( |
quartz are not always solution for repair this |
where a solution please help!!! |
there are two solutions: 1) Easy: resend back to you resseler for chaneg Box 2) Complicated: fidn where problem are..if nothign helps so Atmega it's death and must send back to resseler |
Sws Sag Bad Box Never Buy It As Many Times As U Can Get Replacement As Many Times It Will Get Bad!!!! Dont Delete My Post!!!! |
yes, i got this problem with two box, after changing it, the 2nd dead too, in some days, very bad box, and this solution of sending back to reseler is stupid. |
