04-04-2006, 14:19 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Sahiwal Punjab , Pakistan
Member: 123133 Status: Offline Sonork: 100.999 Thanks Meter: 911 | MyX-1trio.... Problem Myx-1 Trio Searching Phone...Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Firmware : 5713204006985 JA3,VG: 020305 0857 - Phone Imei: 357833002373937 - Hash Table : 13 01 01 - Phone Code : 00000000 Searching Phone...Found. Reading Phone Info : OK. - Phone Firmware : 5713204006985 JA3,VG: 020305 0857 - Phone Imei: 357833002373937 - Hash Table : 13 01 01 - Phone Code : 00000000 Connecting to server... OK!!! Asking server for access...OK. Sending Phone Data to server...OK. Waiting Server Answer...OK. - High Code : 3168026043 Hex : BCD43DBB But Problem Is That Phone Only Take 8 Digit Codes 316802643 & Stop For Take 4 And 3.. With Out Simcard Phone Shows Insert Sim ..And With Sim 70 Hours For Unlocking Time.. Can I Try To Direct Unlock This Phone With SWS SAG Box ? http://mobilewala.com/forum/showthread.php?t=70 WBR Kuku |
04-04-2006, 14:30 | #2 (permalink) | |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | hi man did you try with these 8 digit only !! also you can try to direct unlock this phone br <= The_Gorr => did you try Quote:
04-04-2006, 15:20 | #3 (permalink) |
Member: 123133 Status: Offline Sonork: 100.999 Thanks Meter: 911 | Yes Sir.. I Tried These First 8 Digits..But Phone Need 70 Hours.. OKI I WILL TRY DIRECT UNLOCK Thx For Kind Help WBR Kuku |
04-04-2006, 15:24 | #4 (permalink) | |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | 70 h many codes tryed wrong code counter must be reseted good luck br <= The_Gorr => Quote:
04-04-2006, 15:36 | #5 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jan 2005 Location: U S A / GOA /CHINA Age: 44
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | try this Quote:
SOMETIMES IT FAILED ALWAYS CONNECT GROUND TO PHONE TP ADPTER [8] AND EVERY THING GOES NORMAL THNKS | |
04-05-2006, 06:36 | #6 (permalink) |
Cheater -Don't Deal with him- Join Date: Apr 2005 Location: Iclouds
Member: 142219 Status: Offline Sonork: 100.107814, Thanks Meter: 368 | yes always groung pin no 8 of your doungle to mobile.then you can unlock any mobile in first try by sws-sag.before this trick i also get fedup with this box saying"bad test points". regards mobilecraker |
04-07-2006, 12:36 | #8 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: Bled lekhla
Member: 27291 Status: Offline Thanks Meter: 81 | Quote:
so as It doesn't work untill linking pin 8 with the gnd why they aren't made the cable with this trick @ SWS factory and let the owners working on unlock and flash not losing time on making a wires and cables ... | |
04-07-2006, 13:27 | #9 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | Quote:
, and after repaiur cable is very easy if is damajed all what you need to know is RJ45 name pinout form SWS-SAG and you can solve your problem | |
04-07-2006, 15:39 | #10 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Delhi
Member: 138575 Status: Offline Thanks Meter: 58 | I DIN'T UNDERSTAND ANYTHING. PLEASE BE MORE SPECIFIC. WHICH PIN OF WHAT HAS TO BE GROUND OF MOBILE. THE JIG HAS ONLY FOUR POINTS, WHICH NONE ARE GROUNDED. SO WHICH ONE HAS TO BE GROUNDED. BR jackle123 |
04-08-2006, 10:29 | #11 (permalink) |
Member: 123133 Status: Offline Sonork: 100.999 Thanks Meter: 911 | @ all who suggest me to use ground cable Sir.. I Read Codes..ITs Meant All Is oki From Cable...and sws shows 10 digits codes always ..so no problem with software or cable... problem is phone not accept that 10 digits code..only stop in 8 digits.. understand ? WBR Kuku |
04-08-2006, 15:12 | #12 (permalink) |
Member: 123133 Status: Offline Sonork: 100.999 Thanks Meter: 911 | Searching Phone...Found. Reading Phone Info : OK. - Phone Firmware : 5713204006985 JA3,VG: 020305 0857 - Phone Imei: 357833002373937 - Hash Table : 13 01 01 - Phone Code : 00000000 Connecting to server... OK!!! Asking server for access...OK. Sending Phone Data to server...OK. Waiting Server Answer...OK. - High Code : 3168026043 Hex : BCD43DBB PS : If code are wrong plz go to flash panel and read full flash and send to : [email protected] Unlocking Phone..OK. Phone Is Unlocked..Special Thanks To Stanner_austin..who help me for this WBR Kuku MobileWala Team |
Testpoint Adapter For Sagem MyX-1trio | JKKB | SAGEM JTAG UNLOCKER | 1 | 11-16-2008 14:59 |
MyX-1trio Unlocking Prob ... | ~mr_Ten$ion~ | SAGEM JTAG UNLOCKER | 4 | 07-25-2007 11:16 |
tespoin myX-1trio? | halongmobile | ARM9 BASED M62 / M62+ | 5 | 04-05-2006 11:16 |
myx-1trio can only enter 8 digits of unlock code !!!! | chavrotti | SagMaster Team OLD Products | 5 | 01-31-2006 14:59 |
sagem myx-1trio unlock ????? | iletmek | ARM9 BASED M62 / M62+ | 2 | 07-18-2005 13:00 |
