02-14-2005, 12:35 | #1 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Here Age: 60
Member: 16916 Status: Offline Thanks Meter: 3 | NEC E606 unlock ??? Can I use simply max232 interface Rx,Tx and GND with furious dongle soft? Just to use inside points for Rx,Tx ? wbr Zive P.S. Should I (and how) to check phone soft version? |
02-14-2005, 12:48 | #2 (permalink) |
No Life Poster Join Date: Sep 2002 Location: India
Member: 15238 Status: Offline Thanks Meter: 128 | Yes u can.. try to search and read old posts before starting a new thread. U can start with moto t19x cable OR simply use siem a55 cable. Note which colors are tx, rx n Gnd. Then connect it to the desired points. IF not works at first try twice thrice. IF not then invert Tx n Rx. Regards ps: no need to see phone version. ONLY keep battery charged. |
02-14-2005, 13:28 | #3 (permalink) |
Member: 16916 Status: Offline Thanks Meter: 3 | Thanks. I will use other max232 interface use it for car radio decode.... wbr Zive P.S. How time takes to unlock? Not to desconect cable if last to long |
02-14-2005, 14:32 | #4 (permalink) |
Member: 16916 Status: Offline Thanks Meter: 3 | I tried but no luck After I press unlock I press power On button (hold until phone is ON) and then write on soft "REMOVE BATTERY NOW" but phone is still locked. If I replace Rx,Tx then nothing happend... and after while "wrong connection" Any help? Ziko P.S. I just tried on other PC same situation bu tsometimes ERROR CMD1 show P.S. 2 Don't bother, I return phone , still locked of course. Thanks FT !!! Last edited by ziko; 02-14-2005 at 15:33. |
Nec e606 unlock | besi_al | NEC | 25 | 05-12-2012 11:06 |
nec e606 unlock code | crossings | Phone Unlocking Codes & Maps | 4 | 05-29-2010 13:32 |
Nec e606 unlock | mailhassan | Phone Unlocking Codes & Maps | 10 | 06-10-2004 15:26 |
Also want the nec e606 unlocked | atomictom | Phone Unlocking Codes & Maps | 1 | 09-06-2003 15:13 |
