11-30-2004, 19:53 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: ISLAND Age: 53
Member: 80036 Status: Offline Thanks Meter: 25 | sagem-calc not running! i reinstall all furious, last version dongle c finally all programs runing, only sagem calc nothing i put the sagem key into dir. but nothing -the program doesn't run any solution? |
12-01-2004, 23:32 | #4 (permalink) | |
No Life Poster Join Date: Nov 2002
Member: 17424 Status: Offline Thanks Meter: 15 | Quote:
Look in Sagem folder, if there is a file called sagem.key then either rename to anything else or delete it. run the programme again and it will give you a long string of numbers which you need to input into activation server to get the new sagem.key regards msa | |
12-02-2004, 12:28 | #5 (permalink) |
Freak Poster Join Date: Mar 2003 Age: 46
Member: 25392 Status: Offline Thanks Meter: 10 | thanks msa but my sagem folder is empty..... sagem is not "key" protected.... the problem is when i start sagem.exe.....it ask for a key....but i cant see the row where this message has to be displayed: "Hardware fingerprint: xxxx-xxxxx" in my case this fields are BLANK....THE SOFTWARE DOES NOT READ Hardware fingerprint wich i need to calculate the key.... i tested the box on 3 computers...i downloaded the software again..... but....same problemmm |
12-02-2004, 13:02 | #6 (permalink) |
No Life Poster Join Date: Mar 2004 Location: EGYPT
Member: 57430 Status: Offline Thanks Meter: 6 | HI u will find a txt in it codes enter it and then u will arq massage in it key to calculate after using the number in it u will find u key beside the calculator i hope that work with u B.R |
12-03-2004, 19:28 | #7 (permalink) | |
Member: 25392 Status: Offline Thanks Meter: 10 | Thanks Quote:
yes ..this solves the problem.. but in my key.txt file before ...gsmtools.ro give me the new one it was only key for lg and few other.... | |
way not to talk about Stonesuk sagem calc free in this thread | the new | Wallpaper, Applications, RingTones, etc | 8 | 09-09-2004 22:10 |
sagem calc & sagem X5 v JE3,6H | Bomber | ARM9 BASED M62 / M62+ | 2 | 10-16-2003 08:17 |
Sagem 3026 3.5D chris calc not helped. May be you? | egis | Phone Unlocking Codes & Maps | 7 | 12-11-2002 15:12 |
sagem calc v1.3 by guar | bluelights | Infineon C16X M51 & ARM7 M52 BASED | 0 | 10-22-2002 18:49 |
