10-01-2009, 17:50 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Sri Lanka Age: 38
Member: 241637 Status: Offline Sonork: 100.1620549 Thanks Meter: 396 | ::: Successfilly Unlocked Motorola Ve538 ::: ADDED: MOTOROLA VE538 [X] USER CODE READ [X] UNLOCK CODE(S) READ [X] MASTER CODE READ NOTE: YOU MUST HAVE A SIM INSIDE ! WHEN PHONE IT’S ASKING FOR ‘N.P CODE – MASTER CODE’ PRESS UNLOCK. AFTER CODES READED PLEASE ENTER THEM WITHOUT RESTARTING THE PHONE. IF YOU RESTART YOU MUST REPEAT THE OPERATION; ALSO ADDED SOME NEW FWS FOR KE990, TS705 SW DL LINK: http://rapidshare.com/files/28729817...1.0.0.2950.rar DRIVER LINK: http://rapidshare.com/files/28729613...38_DRIVERS.exe FLASHER LINK: (USE ONLY IF PHONE IT'S MALFUNCTIONING - FLASH HAS EN-TW LANGUAGES ONLY SO DONT USE IF YOU DONT NEED) http://rapidshare.com/files/28729782...V008_RV001.exe |
The Following 12 Users Say Thank You to indikait For This Useful Post: |
10-16-2009, 10:50 | #4 (permalink) |
No Life Poster Join Date: Dec 2005 Location: algeria
Member: 206173 Status: Offline Thanks Meter: 169 | hello plz furio team help i cant unlock this phone is it insupported vers? Software engine version: 1.0.0.2950 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Mar 16 2009 11:10:00 RELEASE DATE : Mar 16 2009 10:05:00 FIRMWARE INFO : O'zapft is000Athens2.08ATHB1A_2.08P0 IMEI : 35687702029953-4 BLUETOOTH ADDR : A5 C6 5A CA 17 00 MEMORY ID : 00AD:0036 MEMORY NAME : hynix_HYC0SEH0AF3P MEMORY INFO : 0200:0020:06ED INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; DATA FOUND; PHONE CODE: 1234 Time needed - 00:00:17 |
10-16-2009, 11:48 | #5 (permalink) |
Member: 206173 Status: Offline Thanks Meter: 169 | hello ,i forgt to tell u that phone auto restart after the unlock opperation and cant read the unlock codes plz help |
The Following User Says Thank You to yahia ali For This Useful Post: |
10-17-2009, 18:33 | #8 (permalink) |
Member: 206173 Status: Offline Thanks Meter: 169 | problem solved by using the last vers of qcom vers 1.0.0.3071 all is ok Software engine version: 1.0.0.3071 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Mar 16 2009 11:10:00 RELEASE DATE : Mar 16 2009 10:05:00 FIRMWARE INFO : O'zapft is000Athens2.08ATHB1A_2.08P0 IMEI : 35687702029953-4 BLUETOOTH ADDR : A5 C6 5A CA 17 00 MEMORY ID : 00AD:0036 MEMORY NAME : hynix_HYC0SEH0AF3P MEMORY INFO : 0200:0020:06ED INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; DATA FOUND; PHONE CODE: 1234 RL STARTED; RL DONE; UNLOCK CODE(S): 90716525 MASTER CODE: 95186396 ENTER CODE(S) NOW ! DO NOT RESTART THE PHONE ! IF PHONE DOESN'T ASK ANY CODE OR YOU RESTART IT THEN REPEAT THE OPERATION ! Time needed - 00:00:09 |
12-23-2009, 11:37 | #9 (permalink) |
Junior Member Join Date: Jul 2008 Location: Indonesia
Member: 815423 Status: Offline Sonork: 787874 Thanks Meter: 2 | can you share again...please..SW DL Link http://rapidshare.com/files/28729817...1.0.0.2950.rar not found in rapidshare. |
The Following User Says Thank You to jamot78 For This Useful Post: |
07-19-2010, 00:25 | #14 (permalink) |
Junior Member Join Date: Jul 2010
Member: 1345351 Status: Offline Thanks Meter: 1 | Pls help. I have a moto VE538. Dont know the mastercode of the phone, 000000 wont work. How will I read the mastercode using the software above. Are the links still available for download? What will be Im needing. Dont know how to start. Dont have any software. I just got the USB cable. Please give me some step-by-step guide. Thank you very much in advance. |
09-09-2010, 08:22 | #15 (permalink) |
Banned Join Date: Nov 2007 Location: kathmandu
Member: 624910 Status: Offline Sonork: 1611605 Thanks Meter: 9 | RapidShare: 1-CLICK Web hosting - Easy Filehosting link is not working plz upload again thanks to indikait Last edited by sprashant; 09-09-2010 at 08:30. |
how to Unlock Motorola VE538? | BackSlash_cu | Smart-Clip | 2 | 03-29-2010 09:35 |
::: Successfilly Unlocked Motorola Ve538 ::: | MOBIL CLINIC | FuriousGold | 5 | 12-28-2009 10:25 |
How to unlock Motorola W175? ::: ANSWERED ::: | asson | PolarBox 3 | 11 | 02-19-2009 01:15 |
