06-16-2005, 10:36 | #2 (permalink) |
No Life Poster Join Date: Dec 2003 Location: United Kingdom, ENGLAND
Member: 47774 Status: Offline Thanks Meter: 185 | Man , just you need to visit this web page. http://www.furiousbox.com/inside.php...&model=install http://www.furiousbox.com/inside.php...del=activation and for more any info just post here i try to help you Enjoy Welcome to Furious Planet the best Box |
06-16-2005, 22:05 | #3 (permalink) |
Junior Member Join Date: May 2005 Age: 54
Member: 142551 Status: Offline Thanks Meter: 0 | I have a problem with installing the driver for the furious box, I have run, install driver, and said was succefful, but it keep asking for serial -usb control driver.and I can not find the driver on furiousbox website, any help will be appreciated. |
06-16-2005, 22:29 | #4 (permalink) | |
Member: 47774 Status: Offline Thanks Meter: 185 | Quote:
Man , you can download it from support area or this link and just install it ! http://www.mrfgsm.net/accsse/index.p...Furious%20Box/ Furious Box http://www.furiousbox.com | |
The Following User Says Thank You to .:Morpheus:. For This Useful Post: |
06-16-2005, 22:35 | #5 (permalink) |
Member: 142551 Status: Offline Thanks Meter: 0 | Dear Morfeus, I have tried that many times, and it reports success. and after ward a driver window apears asking me for a driver. I am usning WinMe, is that a problem ? Thanks in advance |
06-16-2005, 22:55 | #6 (permalink) |
Member: 47774 Status: Offline Thanks Meter: 185 | Forget all and make what i have write 2 u .... downloaded latest version of FuriouS BoX Software. FuriouSBox2 v1.0.0.816++ (Setup Program) 1- Run Install.exe 2- Now select folder where you want install FuriouS BoX Software. Then press Next button 3- When you see this message that mean you have successfully instaled FuriouS BoX software on you computer. 4- Now go on folder where you installed FuriouS BoX Software and run drivers installation. 5- Click on install button and wait around 10 seconds. 6- Reboot ur computer 7- NOW and ONLY NOW CONNECT YOUR FURIOUS BOX. 8- Your FuriouS BoX is correctly installed and ready to work. Last edited by .:Morpheus:.; 06-16-2005 at 23:24. |
06-16-2005, 23:44 | #7 (permalink) |
Member: 142551 Status: Offline Thanks Meter: 0 | Thanks for the fast response , I have done exactly as you said, but still the same problem. I will explain: -There are two cables coming out of the box, one is usb and one is serial. -I have un-installed every thing relating to furious and done the instruction you sent. -after rebooting the pc, I have pluged the usb and was fine and when I plug the usb-serial cable asks me for the driver? and in the device manager it shows me a question mark on the "usb-serial control " device as unknown. -I can open serial box software window, and there are two ports appearing, and when I tried to read code for LG, it said press power shortly and nothing happen. - so I think the driver is not working well. I am runing winme. Thanks |
06-16-2005, 23:57 | #8 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Br | |
is it possible to use furious box 2 on windows me | chowdary | FuriouS II | 1 | 05-31-2005 21:47 |
