lg 8180 certificate error hi guys, got an 8180 here that was badly flashed, now when i try to flash it i get this http://www.dj-ped.com/gsm/errorf2.JPG what can i do? |
very easy ................you should make test point |
this is what i get with test point Press Power On shortly ! Phone Detected ! Chip ID: 71000301 Loading ... Loader version: 40318 1450 LLECXC1325413_CERTLOADER R3J Flash ID: 8900 Settings Done ! Certificate sent ... HACK3R2K.COM GSM DEVELOPEMENT Settings made ... CID: 17 IMEI: 35554900584366-6 U8180_DRIVEC.csw CSW BLOCKS: 00C8 U8180_DRIVEC.csw ... ERROR U8180_DRIVEMEDIA.csw CSW BLOCKS: 0048 U8180_DRIVEMEDIA.csw ... ERROR U8180_FLEX.csw CSW BLOCKS: 01E0 U8180_FLEX.csw ... ERROR U8180_MAIN.csw CSW BLOCKS: 00DA U8180_MAIN.csw ... ERROR READY. |
select 8180TP............................. |
that WAS with test point |
USE EPI NOT FTDI IN the soft |
Br;) |
ive tried all settings and options.. thanks hack3r pm sent |
Br;) |
thanks, will let you know what happens :cool: |
Hello >>>hack3r2k >> Need Password For this file http://www.hack3r2k.com/U8180F_V11b_...ID17_BROWN.rar. My FB User Name Furiousbox488 & My email address is [email protected] Please reply Me..... |
Br;) |
Hi Hack3r ...didnt help :( http://www.dj-ped.com/gsm/errrrr.JPG Press Power On shortly ! Phone Detected ! Chip ID: 71000301 Loading ... Loader version: 40318 1450 LLECXC1325413_CERTLOADER R3J Flash ID: 8900 Settings Done ! Certificate sent ... HACK3R2K.COM GSM DEVELOPEMENT Settings made ... CID: 17 IMEI: 35554900584366-6 drive_c.Csw CSW BLOCKS: 00C8 drive_c.Csw ... ERROR drive_media.Csw CSW BLOCKS: 0048 drive_media.Csw ... ERROR drive_Rec.Csw CSW BLOCKS: 0028 drive_Rec.Csw ... ERROR U8180_phone_wcdma_4mbram.Csw CSW BLOCKS: 00E7 U8180_phone_wcdma_4mbram.Csw ... ERROR U8180F_FileSystem_TW.Csw CSW BLOCKS: 01B8 U8180F_FileSystem_TW.Csw ... ERROR READY. and before someone says "use EPI" ect , ive tried ALL options and ALL settings, with a full battery. |
see in the soft .notch on use EPI .and tel me the result |
its the same as the above error whatever i do.. |
