Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > FuriouS II
Old 03-16-2006, 15:26   #1 (permalink)
vertz's Avatar
Member: 173878
Thanks Meter: 295
NEC PLUGIN HW-ID Problem..
I've been using FuriousBox2 for quite sometimes now, and this is the
first time that i have encountered a problem, it all started when i
reformat my laptop,when i open FuriouS Box II Client v1.0.0.142
i cannot enter NEC PLUGIN HW-ID. A friend of mine told me to use the
old version of FuriouS Box II Client, well, i can't confirm if its
working cause the old version is no where to be found..
Please Furious Team,.:hack3r2k:., Help me solve my problem.. Thanks in advance..
Old 03-16-2006, 15:35   #2 (permalink)
garch's Avatar
Member: 138305
Thanks Meter: 2
use last version
unistall from windows control panel
erase any previus directory of F-Box
reinstall F-Box
start client check for Firmware, must be v2
Old 03-16-2006, 15:39   #3 (permalink)
vertz's Avatar
Member: 173878
Thanks Meter: 295
ok, I'll try that and post the result, thanks for your quick reply...
Old 03-16-2006, 15:55   #4 (permalink)
vertz's Avatar
Member: 173878
Thanks Meter: 295
I have followed your instructions religiously, but whenever i try to
open Furious Main v2235 the box NEC PLUGIN always appears, I enter the
name and serial and then push activate. after that restart the software
then open furious main v2235 again the box NEC PLUGIN appears, but before
that my problem is i can't enter my hw-id in furious client, i can only
get my key, that's all, please help me...
Old 03-16-2006, 16:36   #5 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 61,132
See tutorial and read it carefully. Key for NEC u generate using client.
Old 03-17-2006, 03:00   #6 (permalink)
vertz's Avatar
Member: 173878
Thanks Meter: 295
Sir, i read the tutorial carefully, i can generate the key but i can't enter the
HW-ID to the slot where it is alloted to, it does not allow me maybe it has
something to do with the paidupdate, sir if you have the old installer before the paid update was introduce i would like to try that sir, pls give me link..
Old 03-17-2006, 15:40   #7 (permalink)
Member: 15022
Sonork: 100.53452
You must uncheck System Key Only in order to be able to enter HW-ID in cliuent.
Old 03-17-2006, 16:14   #8 (permalink)
vertz's Avatar
Member: 173878
Thanks Meter: 295
sir, thank you very very very much, you're such a great help, i did exactly
what you say, uncheck system key only, and after that i have enter hw-id..
more power to you sir .:hack3r2k:. and keep up the good work....thanks.
Old 04-02-2006, 22:07   #9 (permalink)
Member: 139206
Thanks Meter: 9
hi I am new here and I have a pbm with fb2 after the formatting of my
PC and to install v1.0.0.2272 the software requires of me to activate
the nec plugin and I cannot ecrire the hw-id on furiousclient to help
me please
Old 04-04-2006, 09:52   #10 (permalink)
Member: 43197
Thanks Meter: 10
hello when i am going to install new version 2272,client versions also new when goto system key always say invalid account ,but working at furious support,so plz help me mr steve,thanks.
Old 04-04-2006, 14:23   #11 (permalink)
FuriouS TeaM's Avatar
Member: 4584
Sonork: 100.69564
Thanks Meter: 15,094
When you run FuriouS BoX 2 software, it will ask you for registration name and serial number. You need to use the server again to obtain this Key.
Quant vous lancerez le logiciel FuriouS BoX 2 pour la premiere fois, un login et serial number vous sera demander vous utiliser le modules NEC3G.
Vous devez utiliser le server pour obtenir cette clé dactivation pour le module NEC.
Now run FuriouS Client enter NEC PLUGIN HW ID and press connect. You receive your key in real Time.
Maintenant entrer votre NEC PLUGIN HW ID dans le FuriousClient.exe puis appuyer le bouton connect.Vous recevrez en temps réel la clé dactivation pour le module NEC.
Now enter data sent by server in NEC PLUGIN window also enter your username (SAME AS FURIOUSCLIENT). Press Enter Serial Button
Maintenant entrez le numéro de série obtenue avec le FuriousClient puis entre votre nom dutilisateur (COMME CELUI DU FURIOUSCLIENT). Appuyez sur le bouton Enter Serial
You must restart FuriouS BoX software to finish the registration. Now the NEC PLUGIN is active in your FuriouS BoX.
____________
Vous devez redémarrer le logiciel pour valider lactivation du NEC PLUGIN.
BR.
Steve.
Old 04-04-2006, 14:42   #12 (permalink)
Member: 139206
Thanks Meter: 9
thank you my friend yassirovic has who has regle the pbm by giving me
the solution
Old 08-01-2006, 14:03   #13 (permalink)
Crazy Poster
Member: 170987
Thanks Meter: 2
invalid
i follow that instruction to the letter and all i get is account invalid how do i make my account valid surely only furious team can valid my account no ammount of installs uninstalls will fix that problem so what is wrong with my account.
i am sick of waiting now so please hurry.
Old 08-01-2006, 21:35   #14 (permalink)
Member: 15022
Sonork: 100.53452
Try now pls. Sorry for waiting.
acount id problem.help uregent plz [SOLVED] dani2080 PolarBox 3 2 03-29-2010 12:46
Nec Plugin activation problem milanbarros FuriouS II 3 07-12-2005 21:20
NEC Plugin remoteunlocker. FuriouS II 8 04-16-2005 19:42
NEC plug HW-ID Csinmaz FuriouS II 0 03-19-2005 02:59
Nec Plugin Activation!!! tt_full FuriouS II 8 03-09-2005 01:19
Page generated in 0.19488 seconds with 9 queries
