12-21-2005, 14:25 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | K700i Hang on startup....... |
12-22-2005, 12:44 | #3 (permalink) |
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | Not Yet Fixed............. i have Flashed the phone with different firmware detatils are after transforming the CId 29 --> 36 : K700i_MAIN_EU_EMEA_US_R2AT003_CID36.fb2 K700i_FS_EMEA1_R2AT003_CID36.fb2 but phone is still in that condition plzzzzzzzzzzzzzzzz HELP |
12-22-2005, 12:52 | #4 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 41
Member: 170313 Status: Offline Thanks Meter: 46 | iam already face this problem and iam flash diffrent file and diffrent k700i but problem still this problem main reason is phone is water damage no more try flashisg its hardware problem |
12-22-2005, 17:38 | #5 (permalink) | |
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | hmmmmmmmmmmm............... Quote:
heat the bluetooth ic or something.................... have u fixed ur phones with hardware repair or not?????????????? | |
12-23-2005, 02:55 | #6 (permalink) |
Insane Poster Join Date: Jan 2005 Location: yemen
Member: 102297 Status: Offline Thanks Meter: 3 | Let me know how you get on. Also if you get the "Bluetooth license check failed. Please make sure that the bluetooth device you are using is licensed..." please post the exact message, there may be a number between the words CHECK and FAILED. I have placed these numbers into the various dll's so that I can see which dll is triggering this. |
12-23-2005, 08:30 | #7 (permalink) |
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | Not a BlueTooth Problem Faresmonmon....... i have a K700i it just hangs on startup... on Language Selection Menu... i have flashed the phone unlocked it try different versions different Language packages ... phone flash normally all ok ... but when i switch on the phone it still in that condition .. but it works fine without simcard inserted... |
K700i hang on startup !!!!! | BENCHENA | Cruiser Suite | 19 | 05-26-2007 04:47 |
K700i hang on startup with SIM card | gurinder | Sony Ericsson | 1 | 05-10-2007 09:49 |
K700i hang on the RSA unlock | bart3 | Cruiser Suite | 12 | 08-12-2006 12:48 |
K700i hang on startup | birocip | Universalbox | 17 | 02-17-2006 07:23 |
**myx1 twin hang on startup (!)*** | infogsm | ARM9 BASED M62 / M62+ | 5 | 06-06-2005 08:18 |
