Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > PolarBox 3
Old 11-17-2009, 17:12   #1 (permalink)
Member: 638779
Thanks Meter: 201
how can i connect samsung s3650 with pc for unlock it [SOLVED]
how can i connect samsung s3650 with pc for unlock it ?
Old 11-17-2009, 19:02   #2 (permalink)
The_Gorr's Avatar
Member: 145648
Sonork: 100.100487 The_Gorr
Thanks Meter: 23,034
- Phone Status ON
- Use E210, Rj45 + USB Datacable
- install drivers
- Press Read Codes to Unlock ur phone
br
<= The_Gorr =>
Old 11-17-2009, 19:55   #3 (permalink)
Member: 638779
Thanks Meter: 201
the problem is : pc can t find the phone ??
im using the correct cable
Old 11-17-2009, 20:10   #4 (permalink)
The_Gorr's Avatar
Member: 145648
check cable, check phone connector
br
<= The_Gorr =>
Old 11-17-2009, 20:19   #5 (permalink)
Member: 638779
Thanks Meter: 201
I called the client to give me the original cable to check it
i thing is connector problem !!
Old 11-18-2009, 01:42   #6 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
if ur phone is not reconized in the device manager,u cant unlock it first check user code if activeted,because if it is active ur pc cant detect phone,try to put phone in download mode and plug usb by this way u will know if it was a drivers problem,also try to format phone then put it into qualcom mode
regards
Old 11-28-2009, 20:30   #7 (permalink)
Member: 638779
Thanks Meter: 201
hi
i thing i have probleme en cable E250
now i cant connect samsung S5230 !!
pleese post her pinouts of hibryt E210 cable
because rj45 work very good i unlok sam samsung with it
br
Old 11-28-2009, 20:38   #8 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
hi
br
hi:
if u have usb cable e210 and rj45,so u can unlock with both of them:
1.connect ur phone to usb port,click unlock when the soft reconize ur phone
2.after restart phone remove usb cable and batterrie,plug rj45(pluged in the pb2) to powered off phone then press power button u must see in the lcd boot loader
3.after restart phone quicly remove rj45 then plug usb cable(fast)
it work very well for all broadcom samsung tested by me simply because i dont have combo cable
test and post result
Old 11-28-2009, 20:46   #9 (permalink)
Member: 638779
Thanks Meter: 201
hi frind
i dont have it i have only hibryt cable and pc dont reconize the fone
Old 11-28-2009, 20:48   #10 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
hi frind
ok i will search for combo cable pinout
stay tuned
check this post i think u will succes
http://forum.gsmhosting.com/vbb/showthread.php?t=628031
luck
The Following User Says Thank You to toutou_gsm For This Useful Post:
Old 11-28-2009, 21:03   #11 (permalink)
Member: 638779
Thanks Meter: 201
thnx man the probleme solved
the cable pinouts its wrong pin 18 copled with pin 20 and i desoldering it and its work
thnx for help
im sory for very bad english
Phone Model : GT-S5230
Phone IMEI : xxxxxxxxxxxxxx
Sending Boot...Wait...
Reading Data...Wait...
Contacting With Server...Wait...
Credits Consumed : 0
Phone Codes...
Net Code : #7465625*638*74286424#
Sub Code : #7465625*782*00000000#
SP Code : #7465625*77*00000000#
CP Code : #7465625*27*00000000#
SIM Code: #7465625*746*12369874#
Activa Code: #7465625*228*12369874#
UnFreeze Code : 57407080
How to Unfreeze Phone
Insert non supported simcard and power on phone
Put Unfreez Code and press key OK (nothing will appear)
Put Network Code (NCK)
Phone will be unfreezed and unlocked
Codes Readed OK...
br
The Following 5 Users Say Thank You to abdel-27 For This Useful Post:
Old 05-20-2013, 15:47   #12 (permalink)
Member: 1793014
Sonork: ps
patson here,am jr member need pinouts rj45 samsung j700,i use polarbox3.thanks in advance.
Old 05-20-2013, 15:55   #13 (permalink)
Haicha's Avatar
Member: 330579
Thanks Meter: 67,515
Friend! You have cable E210? cable is same.
Regards
How can i flash Samsung Z500 with hwk alamgir80 HWK 7 11-01-2008 11:46
how can I connect tcl 401 with comport chandankumardas Various CDMA/TDMA Cell Phones 0 10-15-2008 04:28
How can i flash samsung mobile with Astroclip cat2005 Astro Clip 2 11-04-2005 16:16
How can i connect my z1010 with the original usb cable hunt3r Sony Ericsson Media, RingTones, Games 0 12-14-2004 13:10
How can i programm BIC 43E08 with bin for i make roemi box interface??? florinmar Motorola Old Legacy (EMMI) 5 02-21-2002 10:21
Page generated in 0.18836 seconds with 10 queries
