Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > PolarBox 3
Old 10-24-2009, 15:17   #1 (permalink)
Member: 392373
Sonork: 100.1575353
Thanks Meter: 75
lg KP105 ,just want to change language,I killed the phone !! [SOLVED]
Hi,
As title say, i just want to change a lg KP105 language, i flash it with the full flash from support, and know, phone blink at start, only lg logo!
i tired the other file and the phone stay in this situation !
is there a solution for that ?
Old 10-24-2009, 15:57   #2 (permalink)
The_Gorr's Avatar
Member: 145648
Sonork: 100.100487 The_Gorr
Thanks Meter: 23,034
did u checked imei !!
br
<= The_Gorr =>
Old 10-24-2009, 16:03   #3 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
Originally Posted by .:ramtelecom:. View Post
Hi,
check imei if damaged(so must to repair it first),or u can read full flash backup from working phone and upload it to ur phone(this is the real solution)
regards,
Old 10-24-2009, 16:07   #4 (permalink)
Member: 392373
Sonork: 100.1575353
Thanks Meter: 75
Yes, Imei changed, but can't rebuild it cause phones can't power on.
Old 10-24-2009, 16:09   #5 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
ur working solution is to read full flash backup from working phone,and upload it again to ur phone
luck
Old 10-24-2009, 16:54   #6 (permalink)
Member: 392373
Sonork: 100.1575353
Thanks Meter: 75
luck
So, the full flash from support will not fix that??
Old 10-24-2009, 16:58   #7 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
in the support area,only firmware files not full flash( alchemie and data),i serach too for this full flash backup if i found it i will post link here in this thread
regards,
Old 10-24-2009, 17:18   #8 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,526
Don't worry friend your phones is not killed, what you need to do is:
1) Repair Eeprom (after this your phone will power on again just need step 2)
2) Rebuild IMEI
Luck!
Old 10-24-2009, 17:26   #9 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
2) Rebuild IMEI
Luck!
dont fixed by this steps,some problem
Old 10-24-2009, 17:29   #10 (permalink)
Member: 392373
Sonork: 100.1575353
Thanks Meter: 75
2) Rebuild IMEI
Luck!
thanks but i think we're not talking about the same box
i can't do Repair Eeprom with polar for this model, and there's no eeprom file on support to write it !
Old 10-24-2009, 17:37   #11 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
i alrerady tryed with other boxe,even write eeprom not fixe my problem,always bling,so stay tunned i will search for working full flash backup readed by pb2
Old 10-24-2009, 17:40   #12 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,526
No need to write eeprom, just select Repair eeprom button, will check if button is available or not for this model...
Old 10-24-2009, 17:42   #13 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
even repaier eeprom dont work for this case,i think only full flash readed by working phone will solve the problem
Old 10-24-2009, 17:44   #14 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,526
Read THIS, it was some time ago but is basically the same procedure you need to do, luck
The Following User Says Thank You to y3kt For This Useful Post:
Old 10-24-2009, 17:58   #15 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
i confirm blink phone fixed by repair eeprom,but the imei is damaged,hope polar will support repair imei for this model
the phone work now very well after repair eeprom by pb2,and repair imei with other box
@.::ramtelecom::.
u can repair phone blinking with button repair eeprom in the service software,after try to repaie imei with other tool,mut work,i have now working kp105
best regards to all and specialy y3kt
Just want to change language w395 imamchoo SETool2 3 11-16-2009 14:08
Chinase miracle, want to changed language?????? eko_java_cell Infinity-Box 3 11-04-2007 11:51
want to change language in punjabi for 1110,1110i sandeepmansa MT-BOX 11 06-20-2007 03:44
I want to change language for 688 DupleX Old Ericsson Phones & Sony Phones 2 05-19-2002 06:01
Page generated in 0.21952 seconds with 9 queries
