Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > PolarBox 3
Old 06-21-2010, 17:30   #1 (permalink)
Member: 7696
Sharp GX33 Unlock = No Network [ANSWERED]
hi!
After unlock gx33 with polar box no network.
can some one help me on this ?
Regrads!
Old 06-21-2010, 17:36   #2 (permalink)
SUUNNYY's Avatar
Member: 885625
Sonork: 100.1589108
Thanks Meter: 2,432
Originally Posted by xweb View Post
hi!
Regrads!
HI FRIEND ARE YOU SURE THAT PHONE DONT HAVE NETWORK PROBLEM BEFORE UNLOCK ??? GO IN NETWORK MENU AND TRY SELECTING NETWORK MANUALLY THIS WILL WORK
REGARDS
««««suunnyy»»»»
[ polar team ]
Old 06-21-2010, 17:58   #3 (permalink)
Member: 7696
Tested by me, before the phone works ok.
after read some threads in this forum it seam that is a problem coused by polar unlock method and other boxes, in some cases the phone become death.
if someone have solution it will be appreciated.
in next update remove gx33 unlock option from polar suit.
Best regards.
Old 06-21-2010, 18:01   #4 (permalink)
SUUNNYY's Avatar
Member: 885625
Sonork: 100.1589108
Thanks Meter: 2,432
Best regards.
DID YOU TRIED SELECTING NETWORK MANUALLY????
REMOVING IS NOT A SOLUTION WE WILL FIX THIS,REMEMBER NOTHING IS PERFECT WE MAKE THINGS TO WORK ACCORDING TO OUR NEEDS WILL CHECK ALGO.
REGARDS
««««suunnyy»»»»
[ polar team ]
Old 06-21-2010, 18:08   #5 (permalink)
Member: 7696
hi!
i haven't a lot of posts in this forum but i am not a beginner.
i have tried manual network options and no network.
I'm not the first
http://forum.gsmhosting.com/vbb/f186...-gx33-1025509/
consider my option, not for me but for all others polarbox users.
Regards.
Old 06-21-2010, 18:31   #6 (permalink)
SUUNNYY's Avatar
Member: 885625
Sonork: 100.1589108
Thanks Meter: 2,432
hi!
I'm not the first
Regards.
I ALREADY TOLD YOU FRIEND WE WILL CHECK THIS AND IT WILL BE FIXED.YOUR EACH REPORT IS IMPORTANT FOR US IT HELPS US TO FIX THE BUGS.
REGARDS
««««suunnyy»»»»
[ polar team ]
Old 06-22-2010, 15:02   #7 (permalink)
pititi1974's Avatar
Member: 43253
Thanks Meter: 157
I had not problem to unlock the GX33, I had made two of them without problem.
Try this, in the dialog mode screen try to do the second option.
Format ("something, not remember") area, after that the screen comeback with **** don´t worry, remove and put the battery, after that make a manual network scan.
It working for me.
Old 07-12-2010, 23:11   #8 (permalink)
kikodog's Avatar
Member: 37736
Sonork: 100.108250
Thanks Meter: 222
Already fixed? i have one here with the same problem....
Old 07-12-2010, 23:23   #9 (permalink)
The_Gorr's Avatar
Member: 145648
Sonork: 100.100487 The_Gorr
Thanks Meter: 23,034
this is not a problem with polar software, cause polar put only phone in correct mode, and u make unlock manually
read @pititi1974 post
br
<= The_Gorr =>
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:06
Page generated in 0.18312 seconds with 9 queries
