ot 385x dead help [ANSWERED] Phone Type : 385X-2DBYFR1 dead after flash with polar box help me |
Hi Please post log of connection and flash used Regards ^FiStrO^ |
Sending Certificate.... Bypassing Security Boot... Bypassing Passed.... Ok... Continue Booting Process...Please Wait... Sending Boot.... Detecting Flash IC. Type .... Flash ID.: 00890004 , Numonyx 32 Mb. Phone IMEI : 356967-04-051104-0 Firmware Ver. : UNI Phone Type : C¹°(Ôxø1ÎË ERROR Phone Not Conected.. Phone Disconnected ... log with boot forced Connecting with phone ... Sending Certificate.... Bypassing Security Boot... Bypassing Passed.... Ok... Continue Booting Process...Please Wait... Sending Boot.... Detecting Flash IC. Type .... Flash ID.: 00890004 , Numonyx 32 Mb. Phone IMEI : 356967-04-051104-0 Phone Connected Ok.. |
I have some questions for you : 1- Why you flashed phone ? 2- Has been touched with any other tool ? This data is not normal and we not write this when we flash Firmware Ver. : UNI Phone Type : C¹°(Ôxø1ÎË 3- Which flashfile did you used it ?? |
ot 385 i flashed the phone because he don't accept nck code i flashed it with polar box only |
same pb plz help mi |
I will study you problem, be patient Regards |
Hi Problem found This is not an error of PolarBox In this model, depend of Flash version change addr of write packets in phone Solved this for the next update Regards, |
Hi Please the 2 users with problems contactme polarcdr @ gmail.com Delete spaces Please sendme info about you phone label Example 385X........ Need flash for unlock/unbrand ? Regards |
Hi silution plz wher is pb |
We will update today with fixment, be patient pls and download in the next hours the new update for flash and repare it ... |
Please, download and install this update and try. Confirm us if phone flashed OK. http://www.polarbox2.net/downloads/P...pdate_v327.zip |
i have same problem with 385x-2dbyfr1 , after flash mobile not power on , try with all files from server here is flash log , only connect in boot forced Engine Compilation Build : 327 Connecting with phone ... Sending Certificate.... Bypassing Security Boot... Bypassing Passed.... Ok... Continue Booting Process...Please Wait... Sending Boot.... Detecting Flash IC. Type .... Flash ID.: 00890004 , Numonyx 32 Mb. Phone IMEI : 356967-04-030033-7 Phone Connected Ok.. Changing Speed Up 921600 Bps... Please Wait... Writing Firmware ... Writing PreBlock 1... Writing Block 1... Writing Block 2... Writing Block 3... Writing Block 4... Please Wait... Finishing Writing... Please Wait... Formating... Can take about 60/120 seconds Writing Firmware Ok... Remove Battery and Put again... Phone Disconnected . |
Perhaps this is the problem, so give me few minutes ... |
Hi friend, I uploaded this new firmwares, please test it. First, test this three for see if phone works : 385a_ALMX1_B34_Firmware() 385x_ALRU1_B34_Firmware() 385x_ALTR1_B34_Firmware() In case not, i prepared this other original firmwares (locked), same than your phone have : 385x_BYFR1_DEFG_Firmware() 385x_BYFR3_I_B75_Firmware() Please, test and report here with some screenshot or copy-paste. With best regards, |
