Put in this thread all unlocked phones that not exist in models list/Any corrections Hi TO ALL, please post in this thread all unlocked phones that not exist in supported list, but success unlocked selecting other models Wha we need here : 1- screen shot if possible 2- log of unlock procedure 3- cable used and phone selected 4- tricks if exist 5- if firmware or country or any infos was readed wrongly please also post correct one. POST OUT OF THIS TOPIC WILL BE DELETED thx in advance, br <= The_Gorr => |
Polar Suite 2.31 LG CG225 and CG225trf unlock Ok..using the same data and procedures Select C1300i (Ti Basec) Cable Lg7050 Direct unlock tested 100% lost the log. LG C2000 select C1300i unlock ok.using the same data and procedures. Cable Lg 7050. This on list the model tested select other model...: Huawei T211 select T201. unlock tested.using the same data and procedures Samsung A516 select A517 and read codes 100ok.using the same data and procedures Samsung T456,T459 direct unlock select E210 .Tested.using the same data and procedures Samsung E2210,E2210L select E2210B.unlock 100ok.using the same data and procedures Samsung N620 select R2xx phone on. cable E700 direct unlock. |
PLAY BOY phone unlocked ok selecting ALCATEL OT V770 after reaching long time i have recovery if polar box can unlock this phone i used V770 cable ,then frash with ot V770 firmware.phone unlocked ok phone is this http://i706.photobucket.com/albums/w...oy_handset.jpg this is log http://i706.photobucket.com/albums/w...reenshot-1.jpg |
unlock e225a only need select e230 model click conect and after click on read codes with e101 cable polar is the best http://i74.photobucket.com/albums/i2...rr/polar-9.jpg |
ZTE MomoDesign-2 is same that Amoi MomoDesign-2 "Amoi MD-2" in supported list. This phones say: ZTE MD-2 under battery. http://i34.tinypic.com/70e05c.jpg - Phone Status ON - Use ZTE F230 USB Datacable - Drivers_Amoi_MD2 from our support - Select in: Amoi/Lg: Amoi MD-2 - Important TRICK: enter a test sim, go Connection settings in menu and set communication mode to USB if PolarBox2 not detect drivers. - All info readed OK. br elcapitel |
Alcatel C65 unlock Ok select E805 model Alcatel C65 is same that Alcatel E805, to put in list... thank to @bautizo for test. log: Quote:
- Use Alcatel OT-Exxx Datacable - Info readed Ok. br elcapitel |
Look.Samsung A516 select A517 and read codes 100ok.using the same data and procedures http://i74.photobucket.com/albums/i2..._gorr/A516.jpg |
forget. W156 full tested select W160.using the same data and procedures Read/Write ok.. Unlock 100%ok. http://i74.photobucket.com/albums/i2...W156unlock.jpg http://i813.photobucket.com/albums/z...th_W156R-W.jpg |
LG CG225 and CG225trf unlock Ok..using the same data and procedures Select C1300i (Ti Basec) Cable Lg7050 Direct unlock tested 100% lost the log. http://i74.photobucket.com/albums/i2...r/Cg225trf.jpg |
These are other models completely proven by other polaruser. LG MG 296 select MG 295. unlock tested.using the same data and procedures LG KP 260 select KP 265. unlock tested.using the same data and procedures LG CG 300 select KG 810 unlock tested.using the same data and procedures LG KG 208 select KG 810 unlock tested.using the same data and procedures ZTE ZTE A933+ select Vdfone 225.unlock tested.using the same data and procedures SAMSUNG SAM E1105T select e1310m .unlock tested.using the same data and procedures SAM S401 select X500 .unlock tested.using the same data and procedures. SAM A117 select B110.unlock tested.using the same data and procedures. These are model completely proven by other polaruser. i their log like test of the test has already been posted with pictures in the case of the samsung the codes are not fiables.when the imei it is to zeros 0000000000000000.en some countries they are not able to sircular(for law)we need reliable solutions. thank you polar team. |
Put in this thread all unlocked phones that not exist in models list/Any corrections Flash ID.: 017E3022 , AMD 16 Mb. Firmware Ver. : 192 Phone Type : V670A-2ARGDO1 Operator/Country : Unknow / Unknow (Orange Dominicana) (37001) Language : Unknow (English, Espanol, Portuguese BR, Italiano, Francais) Phone IMEI : 011492-00-306792-9 Backup File Saved.. Phone Connected Ok.. Contacting With Server...Wait... Credits Consumed : 0 Nck Code : 3225100977 Spck Code : 1259382075 Insert Not supported Sim In The Phone Power ON Type You Code in Keyboard Press OK Key Calculated Codes...OK... Phone Disconnected ... |
Put in this thread all unlocked phones that not exist in models list/Any corrections hello just to let you know that I unlocked an LG CG225 using polarbox2 so you might add the model to the suite. Model: LG G-4011 Cable: LG 7050 heres the log Please Wait..Sending Boot ... Flash ID.: 017E2100 , AMD 16 Mb. IMEI : 011081-00-416070-8 Phone S/W : G4050_SWVer_ Phone Connected OK.... Reading NCK.. NCK Code: 154 Insert incorrect sim and type NCK Code + OK Please Wait..Unlocking ... Some phones SouthAmerican after unlock phone still locked. You must flash phone using any Firmware in polar support. After this, repeat unlock process and phone will be unlocked Phone Unlocked OK.... Enter 2945#*# without a sim inside and select 'Fact. Reset'. please add support for km380 and g180 there are a lot outside :( thanks |
Put in this thread all unlocked phones that not exist in models list/Any corrections hello mates i have unlocked 2 huawei u7315 from movilnet venezuela this way: just need to connect the phone without simcard inside with cable USB VODAFONE 810 selec model HUAWEI U7310 then press read codes button and it will give you the unlock code put any simcard and type the NCK readed by POLAR BOX here is my picture: http://i588.photobucket.com/albums/s...oy85/u7315.jpg thanks to polar team especialy mr the gorr for support i apreciate it enjoy using POLAR BOX |
Put in this thread all unlocked phones that not exist in models list/Any corrections http://www.conceptocelular.com/image...ung_e1085t.jpg Unlock e1085 Direct Unlock Seleccting Model E1075L and Unlock OK Please Wait..Sending Boot ... Reading Phone Data.... Phone type E075L Phone S/W : E0…-šX°˜QÒZ:$\ Phone H/W : • fRRutëdz n Phone IMEI : 012015-00-140188-8 Phone Connected OK.... Please Wait..Unlocking ... Reading Simlock Zone.... Reading Phone Data.... Simlock Backup Saved... Calculating Data..... Writing Simlock Zone... Phone Unlocked OK... WILUNLOCK |
Put in this thread all unlocked phones that not exist in models list/Any corrections team plz correct in the sofware bcoz f200 is not like that its unlocking like f210 or u can unlcok by selecting f210 bcoz the option u give to unlock f200 is not possible in that why to unlock this mobile.i unlock sucesffully by selecting f210 thanx. Searching Phone Please Wait ... Phone S/W Version: F200XXGG6 Phone Imei: 355857-01-006549-2 Unlocking Please Wait... Phone Is Unlocked Ok... |
