Samsung GT-S5600 ERROR Phone Not Readed... [SOLVED] A few minutes ago I try to Unlock one piece of S5600 but I can´t connect it with Polar. Try in all possible way but always an ERROR message. 1. Without check New Security Tab http://img40.imagefra.me/img/img40/2...am_063f19f.jpg 2. Checking New Security Tab http://img40.imagefra.me/img/img40/2...am_7473b81.jpg 3. It hav´nt Personal Lock Code http://img38.imagefra.me/img/img38/2...sm_a64d1e1.jpg Maybe Drivers error???? Or I need use the last update???? Any answer???? Thanks like always Polar Team. Best Regards.................aslam870 |
Try with latest version, (2.2.5) i read something was fixed in it, luck |
u using old update :) last one is 2.2.5 use last update and post report PS: i forget to tell u that u have to use only drivers from support area, if u have other drivers installed in ur computer, plz remove, restart pc, install those u download from support. this should work 100% ;) waiting ur report br <= The_Gorr => |
Hi Remember put you phone in qualcom mode Regards ^FiStrO^ |
Uninstall all Samsung drivers and reinstall using drivers downloaded from Polar Support Site........Nothing, the same message. Now I´m using the last update............Nothing, the same message. Maybe later I try in other PC. Any idea?????? Any way, thanks Polar Team. The Gorr, Fistro and Y3KT (Almost a Polar Supporter) by yours advices and help. We continue trying. Best Regards...................aslam870 |
Hi You need put phone in qualcom mode (with keyboard sequence) and install qualcom drivers Access Control panel->System->Hardware->Disp.Adm. You need this 2 ports: 1 - Modem Samsung (In Modems) 2 - Diag Comport (In Ports COM&LPT) I think you not have Diag Comport installed Ok You can testing change Usb port and testing you cable Regards ^FiStrO^ |
This is a Screen Capture now: http://img40.imagefra.me/img/img40/2...em_09a8eab.jpg I unistall all again and make all manually. Then I post what happend. Thanks and best regards my fiend.....................aslam870 |
Another answer. How can I unistall or remove all Samsung driver on my PC. Because I unistall all Samsung driver from Control Panel and then restar the PC but still drivers installation run automatically. I want to install all drivers manually using divers downloaded from Polar Support Site. Best Regards..............aslam870 |
Hi You have phone connected with Zte drivers Replace this drivers with Samsung qualcom drivers and problem solved Regards ^FiStrO^ |
as Fistro sayed, ur phone is connected with Zte drivers if u don't know how to remove drivers, i suggest u to use a clean computer, will 100% work br <= The_Gorr => |
please where can i find clean computer:) i need it too |
clean computer mean, a computer with new installed windows (no drivers conflict inside) :) br <= The_Gorr => |
:) format OS, i mean if there is any software to clean just drivers thanks regards, |
Hi again Not remove drivers or clean computer I add this name drivers in Polar and please not open new post for this Contactme ... [email protected] Regards ^FiStrO^ |
Problem solved Quote:
Of course that I know how remove drivers but the problem was that I unistall all Samsung drivers and still run automatically. The solution was very simple, the delay of my post because I only can connect to Internet at night. I change ZTE drivers manually and one by one using Qualcom drivers of Polar Support Site. Now all is ok. Here is an screen capture of the devices connected: http://img39.imagefra.me/img/img39/2...vm_d84e004.jpg And here is an image of Polar Soft: http://img38.imagefra.me/img/img38/2...em_8304bd8.jpg Thanks all by his advices and Thanks Like Always Polar Team. Polar never fail. Sometimes we fail with Polar. That´s all the problem. Best Regards....................aslam870 |
