★★★ Users Making home made usb/Rj45 cables Step By Step ★★★ Vodafone 810 and 720 usb cable All part of the original idea of my friend Y3KT, to modify the hybrid cable Samsung V804. In my case I did was take the Samsung 20 pines connector from cable RJ45 of Samsung D900. Lowers the corners from connector Samsung D900 with a mini-drill and plug in perfect in the Vodafone 810. After changing the pinout as shown below: http://img147.imageshack.us/img147/3...e720810yk9.jpg for this pinout thanks to ****. ...and then it was well done my cable vodafone 810, and tested in many Vodafone 810 and 720. http://img112.imageshack.us/img112/1...bvod810on0.jpg jejejje:) this is because I have a lot of work getting new cables that come out, then it makes me myself. I do not live in a country that give a turn and you find yourself with a mobile shop. I hope it will be able to help some of you with this. With best regards, [ PB2 Team ] |
..::step by step how to made at home alcatel easy flash rj45 cable::.. alcatel easy flash rj45 cable ThanK to @aslam870 for this great contribution. Original post: http://forum.gsmhosting.com/vbb/showthread.php?t=629576 ---------------------------------------------- This is a little tutorial to all user. This cable work perfectly and is tested 100%. Is a graffic description and I use an original Polar RJ45 Cable to be modiffy. I preffer pictures than words, because my english is not good. Thank to Polar Team by this Box. 1. I use an original Alcatel OT C701 handsfree connector. http://img37.picoodle.com/img/img37/...nm_7b57179.jpg 2. This is a picture take by me like a gude and made by the Polar Team http://img26.picoodle.com/img/img26/...am_26c4726.jpg 3. Connection in Down Side http://img03.picoodle.com/img/img03/...cm_9f892c1.jpg 4. Connection in Up Side http://img32.picoodle.com/img/img32/...cm_3855921.jpg 5. Finally. Your Alcatel Easy Cable http://img33.picoodle.com/img/img33/...Em_2850479.jpg THANKS POLAR TEAM!!!!!!!!!!!! ------------------------------ |
..::step by step how to made at home ZTE 7310::.. ZTE (7310, A39) Huawei (T158 , T201) datacable It is very easy to manufacture a home made cable ZTE A39 unchanged or cut a cable standard for motorola V3. Only need to do a usb-RJ45 adapter as indicated below. This is the pinout of the adapter: http://img221.imageshack.us/img221/7...noutrh0jd4.jpg This is the cable finally: http://img134.imageshack.us/img134/3...ablemd9vj7.jpg with Br BP_Team |
..::step by step how to made ZTE A139 alternative pin-out::.. ZTE A139 Alternative Pin-Out If you do not have the "ZTE A35 cable" Here they have an alternative pinout of ZTE A139, so for lack of cable does not to cease to unlock the phone :D http://img81.imageshack.us/img81/108...vepinouqh5.jpg And here an idea of how to weld or click below the battery without placing the battery in his place corresponding. http://img220.imageshack.us/img220/6...9fineshvg2.jpg with br PB_Team |
..::how to made other ZTE A139 alternative pin-out::.. other ZTE A139 alternative pin-out All right for great contribution to @The_Dj Here's another ZTE A139 alternative pinout that no more difficult still important. In this case it is very useful when you do not have cable, or plug is damaged, even when the balls of copper below the simcard is not present, or simply want to use this other alternative pinout. http://img401.imageshack.us/img401/2...pinoutswi7.jpg br PB_Team |
..:: Step by step how to made Alcatel C7xx/C8xx alternative pin-out::.. Alcatel C7xx/C8xx Alternative Pin-out and using for UFC_Nokia It is simple, to make an adapter as shown: http://img217.imageshack.us/img217/1...7xxc8xxev8.jpg Connect the cable to the adapter UFC_8 shown above, and connect any Alcatel C7xx/C8xx model, and use the show as a universal charger for the battery out. It should be noted that some models will not be necessary to put the battery out, because the pinout is below this in the Alcatel. http://i74.photobucket.com/albums/i2...adapterrs3.jpg Any idea henceforth using the UFC is welcome: D always respect the original idea. :D P.S: Why not make the cable UFC_Nokia Universal more phone models. Here are a simple adapter that lets you use the number 8 UFC_Nokia cable. GPG_Industries to take forward this idea as an alternative for future UFC cable version. br PB_Team |
