08-18-2010, 11:24 | #1 (permalink) |
Junior Member Join Date: Aug 2004 Age: 46
Member: 78844 Status: Offline Thanks Meter: 2 | 9700 problem with enter code[NOT A PROBLEM-READ FAQS] |
08-18-2010, 11:41 | #2 (permalink) |
No Life Poster Join Date: Jun 2009 Location: Abcyz.
Member: 1055074 Status: Offline Thanks Meter: 7,096 | in pandabox,in software click ,how to ,there will explained all,how inter code.let u some help.may be helpfull for u. Blackberry 8830, 9000, 9500, 9530 Storm Attention! Be extra cautions while entering the code. Blackberry phones have limited number of attempts after which your phone will permanently lock and become "hard-locked". If you received an error after entering the code STOP and contact us with the exact error message. Insert a non accepted sim card Scroll and select "Manage connections" Select "Turn all connections off" Press "Escape" to go back to the "Home" screen Go to "Options" menu and select "Advanced options" Select "SIM card" Select "Show keyboard" (optional) Hold the ALT key or SHIFT key while typing MEPD. You will not see text appear on screen while typing. This opens up a personalization menu Hold the ALT key while typing MEP2. You will not see text appear on screen while typing You should be presented with a prompt "Enter Network MEP Code" Enter supplied unlock code After entering the code press the trackball once Restart your phone and restore connections by following the first two steps Your phone is unlocked Possible issues: In case of issues with one of the steps you can try to use a sim card from another carrier. If you have issues with the phone not recognizing the network, make sure the radio is on by making sure it is not low on power. Sometimes the phone requires you to do MEPPD instead of MEPD and if that occurs, you will need to do MEPP2 instead of MEP2 If you have issues with the network not working after you have finished and the phone isn't low on power, switch from Global to GSM to Verizon a few times (keep on doing) and after 3 times of the process completed, leave it on GSM. Should work now. Blackberry 9530 Storm from Verizon Attention! Be extra cautions while entering the code. Blackberry phones have limited number of attempts after which your phone will permanently lock and become "hard-locked". If you received an error after entering the code STOP and contact us with the exact error message. Turn the phone sideways so you get the full qwerty keypad Insert original sim card Scroll and select "Manage connections" Select "Turn all connections off" Press "Escape" to go back to the "Home" screen Go to "Options" menu and select "Status" Input required info into Guarded Link to retrieve the unlock code Go to "Options" and then to "Advanced options" Select "Sim Card" Hold the ALT key while typing MEPD. You will not see text appear on screen while typing. This opens up a personalization menu Hold the ALT key while typing MEP2. You will not see text appear on screen while typing Press ALT and 2 simultaneously to get number 2. You should be presented with a prompt "Enter Network MEP Code" Enter supplied unlock code After entering the code press the trackball once Restart your phone and restore connections by following the first two steps Your phone is unlocked It's not my Work just copyed For Help.luck Last edited by dani2080; 08-18-2010 at 11:47. |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
