Wrong code Alcatel 7041x [SOLVED] Hi Peter, This code is wrong... Contacting With Server...Wait... Consumed 4 , Credits left: 31 Calculation Data Phone Selected : Alc. OT-7041 Phone ID : 7041X-2BVDES1 Phone Imei : 863859022757491 Nck Code : 2392784984 Spck Code : 4090860845 Nsck Code : 1520433247 Cpck Code : 0915521223 Cck Code : 1985587650 Pck Code : 3558691611 I try 2 times because I update Polar software but always wrong so I ask return this credits, thanks!! Best regards hatrun |
I have the same problem I have the same problem Engine Compilation Build : 353 Contacting With Server...Wait... Consumed 4 , Credits left: 46 Calculation Data Phone Selected : Alc. OT-7041 Phone ID : 7041X-2BVDES1 Phone Imei : 863859021378075 Nck Code : 3849497614 Spck Code : 3589929130 Nsck Code : 1780564041 Cpck Code : 0684301296 Cck Code : 1362621032 Pck Code : 0968030595 |
I have the same problem... Calculation Data Phone Selected : Alc. OT-POP C7 Phone ID : 7041X-2BVDES1 Phone Imei : 863859020408097 Nck Code : 1053733163 Spck Code : 2917901885 Nsck Code : 3002063710 Cpck Code : 0565278604 Cck Code : 2552899271 Pck Code : 1448602658 Insert Not supported Sim In The Phone Power ON Type You Code in Keyboard Press OK Key Calculated Codes...OK... |
I fixed this issue, please try this new codes ... Phone Selected : Alc. OT-7041 Phone ID : 7041X-2BVDES1 Phone Imei : 863859022757491 Nck Code : 0026795546 Spck Code : 1943485175 Nsck Code : 2054709116 Cpck Code : 2526796351 Cck Code : 2166091185 Pck Code : 3558691611 |
Phone Selected : Alc. OT-7041 Phone ID : 7041X-2BVDES1 Phone Imei : 863859021378075 Nck Code : 3944235022 Spck Code : 2125344223 Nsck Code : 3291290279 Cpck Code : 1721788562 Cck Code : 3574649900 Pck Code : 0968030595 |
Phone Selected : Alc. OT-7041 Phone ID : 7041X-2BVDES1 Phone Imei : 863859020408097 Nck Code : 0378587580 Spck Code : 2694008729 Nsck Code : 0069605470 Cpck Code : 4253502436 Cck Code : 3427659768 Pck Code : 1448602658 |
very thanks very thanks, this new nck is correct. |
Good to know :) Thnks for test, Regards, |
Nck Code : 3122666616 Spck Code : 2933958626 Nsck Code : 0446951401 Cpck Code : 0894403396 Cck Code : 0589040045 Pck Code : 2133513211 nck not correct |
Calculation Data Phone Selected : Alc. OT-POP C7 Phone ID : 7041X-2BYGES1 Phone Imei : 863859020931981 Nck Code : 3122666616 Spck Code : 2933958626 Nsck Code : 0446951401 Cpck Code : 0894403396 Cck Code : 0589040045 Pck Code : 2133513211 nck not correct |
Back to this post for to say Polarteam refund my credits, thanks!! |
ot7041x wrong code Hi, please alcatel ot 7041x wrong codes: Engine Compilation Build : 356 Contacting With Server...Wait... Consumed 8 , Credits left: 95 Calculation Data Phone Selected : Alc. OT-POP C7 Phone ID : 7041X-2BYGES1 Phone Imei : 863859022569995 Nck Code : 0399039941 Nsck Code : 3822510548 Spck Code : 1976006790 Cpck Code : 0472061603 Cck Code : 2706219165 Pck Code : 2553424041 Insert Not supported Sim In The Phone Power ON Type You Code in Keyboard Press OK Key Calculated Codes...OK... ---- IMPORTANT ---- If phone not accept NCK, sometimes must be resetted A) Press VOLUME UP + POWER ON (at same time) B) Press KEY # + POWER ON (at same time) C) Press VOLUME DOWN + POWER ON, select CLEAR EMMC and press HOME If the phone requests unlock code Insert the original sim Power ON Type ###765*08# |
Wrong code 3 times, I have only four attempts I understand that is the number to place is the NCK Engine Compilation Build : 367 Contacting With Server...Wait... Consumed 0 , Credits left: 62 Calculation Data Phone Selected : Alc. OT-7041 Phone ID : 7041X-2BYGES1 Phone Imei : 863859021701797 Group 1 Nck Code : 2548301313 Nsck Code : 4059568657 Spck Code : 1613447843 Cpck Code : 2661843597 Sim / Pck Code : 3364350520 Group 2 Nck Code : 2548301313 Nsck Code : 4059568657 Spck Code : 1613447843 Cpck Code : 2661843597 Sim / Pck Code : 3364350520 Insert Not supported Sim In The Phone Power ON Type You Code in Keyboard Press OK Key Calculated Codes...OK... ---- IMPORTANT ---- If phone not accept NCK, sometimes must be resetted A) Press VOLUME UP + POWER ON (at same time) B) Press KEY # + POWER ON (at same time) C) Press VOLUME DOWN + POWER ON, select CLEAR EMMC and press HOME If the phone requests unlock code Insert the original sim Power ON Type ###765*08# Select Network Unlock and enter Nck |
Solved: PolarBox generated wrong code, by server IMEI number is totally different |
