02-14-2007, 13:26 | #32 (permalink) |
Junior Member Join Date: Nov 2006
Member: 401570 Status: Offline Thanks Meter: 0 | Congratulations for your work Kulankendi !! I successfully changed the CDA of my p990i from singapore version to world generic and updated it through SEUS as well, perfect !! Thanks !! |
02-15-2007, 13:23 | #33 (permalink) |
Junior Member Join Date: Feb 2007
Member: 447262 Status: Offline Thanks Meter: 0 | Woohoo! Successfully changed cda to world generic 1. Updated to latest firmware via seus. Thank you kulankendi. Really appreciate all the help. Will promote your server to all my friends using p990. :: This message is posted using Sony Ericsson P990i :: |
02-18-2007, 22:52 | #34 (permalink) |
Member: 449370 Status: Offline Thanks Meter: 0 | Hi KK ... wonderful job man. Everything is perfect ... no double line for CDA (at least for me ) ... flawless update through SEUS. Just one thing: KKClient shuts down automatically after each operation ("Get info" and "Flash") which is little bit confusing ... P.S. (P990i) Is there an even slight possibility that in near feature we will be able to edit/add/remove files from GDFS? ( numpad picture drives me crazy ) |
02-20-2007, 06:38 | #35 (permalink) | |
No Life Poster Join Date: Nov 2006
Member: 384655 Status: Offline Thanks Meter: 517 | did it shut down only on P990i?? I didn't noticed it and I want to fix it. Yes I'll make some file editor in near future, but editing files will not be possible coz reading files is blocked in DB2020. Only Delete/Write/Change Dirs. b.r. Quote:
02-20-2007, 17:48 | #36 (permalink) |
Member: 398747 Status: Offline Thanks Meter: 0 | Hi kk, I have sucessfully debranded my p990i using your services and cannot thank you enough! but may i be cheeky and ask you to confirm if the CDA change can be used on a w950i also? Kind Regards, Nanu*1 |
02-20-2007, 18:40 | #38 (permalink) |
Member: 398747 Status: Offline Thanks Meter: 0 | Jumped the gun a bit mate and changed the cda it went sucessfully heres a screen shot of the phone, just about to do seus what do you think? Here is the paste after cda change but before SEUS: Hold 'C' button and plug DCU60 USB cable. Phone Connected... Detected: DB2000: P990i Series Connecting to server... Phone IMEI: Color: Red ; OTP CID: 49 EROM CID:49 Phone Model:W950i CDA: CDA162014/1 R1A08 PDA: CXC162037 R9C001 Bluetooth Firmware: CXC162088 R1B01 Phone Firmware: CXC162098 R3A02 Flash ID: 0x8964 - Supported MCC+MNC: 000-000 NCK: - Unlocked - 5 NSCK: - Unlocked - 5 SPCK: - Unlocked - 5 CCK: - Unlocked - 5 PCK: - Unlocked - 5 Phone Code : 22239 , MCC+MNC: 234-10 Phone Code lock state: - Asking always. All Done! - Time:00:00:08 |
02-20-2007, 20:06 | #39 (permalink) |
Member: 449370 Status: Offline Thanks Meter: 0 | Yes ... it happens for P990i ... i do not have any other SE phone so I am not able to test it with more models. I can send you the logs if this will help you ( .. and also do some tests ). |
03-04-2007, 23:35 | #41 (permalink) |
Junior Member Join Date: Mar 2007
Member: 461373 Status: Offline Thanks Meter: 0 | Can someone give me step-by-step instructions how to debrand mu w950i please. For example: 1. How do I install KKClient. When I run it nothing happens. 2. Do I have to install EPIUSB drivers or can I use the drivers that come with pc suite? If where do i unzip them to and install them? 3. What is hermione, do i need it, where can i download it from? 4. Should I buy before I start? Sorry but i am a newbie. Not sure if I have posted this to right place so apologies if not. |
02-13-2009, 14:13 | #42 (permalink) |
Junior Member Join Date: Jun 2007
Member: 537238 Status: Offline Thanks Meter: 0 | hello 1) i uninstalled all softwares relating to se. (pc suite, symbian 9 drivers & seus). restart pc. 2) d/loaded kkclient, drivers(usb & hermione) 3) run kk client 3) click read info 4) press c button & plug phone 5) kkclient ask for driver 6) installed drivers 7) data read 8) data read finished 9) kkclient closed just did the whole thing again, and now it says that my account is blocked... ;( Hold 'C' button and plug DCU60 USB cable. Phone Connected... Detected: DB2000: P990i Series Connecting to server... >> Account is blocked! Communication Closed. well i guess it's just my luck! |
02-13-2009, 14:17 | #43 (permalink) |
Member: 537238 Status: Offline Thanks Meter: 0 | This post [email protected] don't answer!!!!!!!!!! P: 88.249.224.17 Value: 8.00 Euro Ordered Credits: 1 Actual Credits: 1 Transaction ID:Do not post to Public PLease quckly answer me I can't make new fireware for my p990İ Last edited by KulanKendi; 02-13-2009 at 16:22. |
02-13-2009, 16:21 | #44 (permalink) | |
Member: 384655 Status: Offline Thanks Meter: 517 | UR account is unblocked and IP too I checked server logs and U have wrong LOGIN in login edit box. copy/paste login again, login start with: payp_xxxxxxx where x are some random digits and letters. also please do not port transaction ID for public, only PM. b.r. Quote:
problem after Change CDA P990 | yangyuan | KULANKENDI Server | 0 | 03-27-2008 10:51 |
For Which Complaints Use The Options ""restore File Field,cid Change,cda "" ? | zone2 | Sony Ericsson | 0 | 01-13-2008 08:50 |
Change CDA code for DB2020 with MT-Box... | kennethtse | MT-BOX | 16 | 05-03-2007 17:11 |
URGENT! Problem after changing CDA in P990 | treza | KULANKENDI Server | 19 | 03-06-2007 05:13 |
@ LEAD, Can we change CDA with Cruiser ? | rjsoo7 | Cruiser Suite | 3 | 02-14-2005 19:45 |
