12-17-2007, 22:03 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: rochdale uk
Member: 396778 Status: Offline Thanks Meter: 155 | K800 red light blanking for 6 times…… I got k800 with red light blanking problem. I tried to repair the EROM but still same problem and I also tried to flash with different flash files it get flashed successfully but when I read the phone software version its show me the old software version its cant change the software version.. Can any1 help me out please? Thanks Here is the log file Connect and Power ON phone. Phone Connected... Detected: DB2020 Series Trying set speed on: 9600 Phone IMEI:-- Color: Red ; OTP CID: 1 EROM CID:52 Flash ID: 0x0000 - Supported All Done! - Time:00:01:05 |
12-19-2007, 21:20 | #10 (permalink) |
Freak Poster Join Date: Nov 2007
Member: 627885 Status: Offline Thanks Meter: 27 | well its the only way to do it look at kulankendi client when you start it it says so on top also, kulankendi post it here many times you need to make sure to change port settings also |
12-19-2007, 21:51 | #11 (permalink) | |
Member: 384655 Status: Offline Thanks Meter: 517 | look at: Flash ID: 0x0000 UR phone is hardware damaged. 0x0000 is wrong flash ID But strange thing coz sw should show unsupported flashID, try to read phone info again and check if flash ID changed. Did U erase IMEI number or that info was readed? b.r b.r. Quote:
bb 8100 red light is blinking 3 times | uburo22 | BlackBerry (RIM) | 7 | 02-16-2010 12:27 |
k800 red light? | ikram tabassum1 | SETool2 | 3 | 06-14-2009 11:13 |
K800 red light blanking for 6 times…… | mobileunlockers | Sony Ericsson Hardware Repair | 14 | 09-13-2008 02:29 |
K800 Red light blinking | SixthSence | Universalbox | 47 | 11-16-2007 14:04 |
K800 Red light Blinking when power on.. | bestncheap | MT-BOX | 3 | 01-22-2007 14:12 |
