GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   KULANKENDI Server (https://forum.gsmhosting.com/vbb/f390/)
-   -   Samsung SGH-P910 unlock codes don't work (https://forum.gsmhosting.com/vbb/f390/samsung-sgh-p910-unlock-codes-dont-work-433115/)
WireBaby 08-16-2007 23:21
Hi all! I have purshased login to server, and Kulan Kendi Multi Client have read unlock codes from my phone, but it don't work!!! The phone show me "Phone freeze" and the unfreeze code don't work! Help me! Or turn me my money back!
KulanKendi 08-17-2007 00:11
To enter phone freeze just enter that code (will not be visible) and accept by middle key.
b.r.
WireBaby 08-17-2007 14:59
I tryed how are you say, don't work, not happened nothing
KulanKendi 08-17-2007 15:14
contact me PM with msn,sonork or icq we will talk online
b.r.
WireBaby 08-18-2007 15:27
I send to you PM with my ICQ number
vince58 05-11-2008 17:33
Samsung SGH p910 UNLOCK
I am inquiring how to unlock my mobile phone Samsung SGH p910. Can somebody help me by telling me how to do so?
Thanks a lot for your help
Regards
vince59
sajidali 05-11-2008 18:40
Regards
vince59
use xsim only 1 solution
KulanKendi 05-12-2008 08:32
no, it can be readed with KK server or direct unlock
b.r.
Birtieddu 05-17-2008 18:53
Hi... I buy a credit to unlock my P910 the program show me the code but it don't work... I have P910NPFG1 firmware... The phone is ok but locked... I try to insert code with sim witouth sim but is the same... The phone is already locked... Can you help me??
KulanKendi 05-17-2008 22:47
send me PM with login, I'll add U credits, U need to use direct unlock method(read instruction how to do it, after select P910 model).
b.r.
Birtieddu 05-18-2008 10:21
OK thanks i sent you a pm!
gsminfo 05-23-2008 09:36
******** P910/P920 Unlocking Instructions ********
>> Read Unlock Codes (USB cable ONLY) <<
1. Connect USB cable to PC
2. Power On phone and connect USB cable
3. If system will ask for drivers then install them from support> Samsung_USBDrivers.exe
4. Select "Read Unlock Codes" and click EXECUTE and wait for unlock codes
5. Disconnect phone and insert 3G(128KB) simcard and power ON phone
6. Phone will show "NETWORK LOCKED" or other lock level
7. Enter ONLY 8 digits from code for lock level and accept with OK key
- Example: Network code is #7465625*638*77300889# then eneter ONLY 77300889 digits
- Note: Some P910 can accept unlock code without simcard so You can enter full combination like #7465625*638*77300889#
>> Read Unlock Codes - Phone Freeze on LCD <<
1. Repeat procedure like for Read Unlock Codes(step 1-4 above) if you don't have unlock codes yet
2. Disconnect phone and insert 3G(128KB) simcard OTHER operator and power ON phone
3. Phone will show "Phone Freeze..."
4. Enter 8 digit P.Freeze code(codes will NOT BE VISIBLE) and accept by OK key
5. If phone will ask for unlock code (when not unlocked before) then do step 7(above)
- Unfreeze Problems: If phone will not accept "P.Freeze" code then it mean that code counter is blocked and phone can be unlocked ONLY with COMBO/HYBRID cable COM&USB together!!
>> Direct Unlock(Unlock Phone) by USB <<
1. Power On phone and enter code *#391746# (test mode menu) press 9 after 6 key,if there is Qualcomm USB selected then is OK if not then press 2
2. Connect USB cable, install drivers from support: QUALCOMM_USB_Driver.rar
3. Go to SETTINGS and click DETECT,select COM port with "Qualcomm Diagnostic..." name and click ACCEPT
4. Select ONLY "Unlock Phone" click EXECUTE and wait till finish.
5. If all was set ok then phone should be unlocked,back phone to Samsung mode - Enter code *#391746# press 9 after 6 key then press 1
If unlocking hang on "Connecting to server" then look next step.
6. Enter code *#265683# (3G Pre-Config menu) and select first,second,third(step by step) and try to repeat unlock, it must work nn one of that conf.setting.
>> Direct Unlock(Unlock Phone) by COMBO/HYBRID <<
1. Connect COMBO/HYBRID cable to PC, Power On phone and connect to cable
2. If system will ask for drivers then install them from support> Samsung_USBDrivers.exe
3. Go to SETTINGS and click DETECT and select COM port on what cable is connected(or box) and click ACCEPT
4. Select ONLY "Unlock Phone" click EXECUTE and wait for unlock codes
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.11577 seconds with 6 queries
