Unlock, reset UserLock and flash language files (other fs) Hi, i want to do all those operation on my W880i. How do i best do this? I have read how to unlock it (it's on T-mobile now). It doesn't seem hard to reset the user unlock code but can i do this in one operation? I also want other FS with europe 3 instead of europe 2. Can someone explain me in what order to do all this and what can be done in the same operation? Do i have to change the CDA? (if yes when?) Why would i upgrade the cid? i don't know any advantage of doing so but if i should please tell me why and when in all those operations. Read info: Hold 'C' or '@' (some PDA) key and plug DCU60 USB cable. Phone Connected... Detected: DB2020 Series Phone IMEI: 35464901-522860-0 Color: Red ; OTP CID: 49 EROM CID: 51 Phone Model: W880i Operator: T_MOB_INT_A CDA: CDA102719/19 R9A Phone Firmware: R1JC002 Firmware CXC: R1JC002_prgCXC1250640_GENERIC_AI Firmware supported for patch unlocking. MCC+MNC: 234-30 - SIM NCK: - Unlocked - 5 NSCK: - Unlocked - 5 SPCK: - Unlocked - 5 CCK: - Unlocked - 5 PCK: - Unlocked - 5 ESL: - Locked - 5 Phone CodeMCC+MNC: 234-30 Phone Code lock state: - Asking always. Total call time: 00:27:04 EROM Version: R3A016 All Done! - Time:00:00:00 After all this is it better to not use SEUS anymore or doesn't it matter? if yes it that because of unlock or because of cid change?? A BIG thanks in advance for some explanation!! Grtz, Antony |
First flash the phone with CID51 flash files that you want. If the program ask you to Update Erom CID DON'T do it, becose your phone can become CID52 and you can't unlock it with Kulankendi. Second Reset the security code. Now after this Unlock the phone. I hope that can help you. |
Ok thanks but i still could use some help: do i need to do everything seperatly and use one credit each time? -flash (debrand main and fs; W880i_R1JC002_FS_EUROPE_3_CID51.fsm and finilize) -Remove user lock -remove sim lock or can i: -flash (free i think) -remove userlock and simlock and finilaze? |
Answers of this questions can give only KulanKendi i think. I think that you will need 3 credit for all operations. If you want wait KulanKendi to answer, he will tell you for sure. |
I tried the interface to see what i could check without the phone connected. I think i can Flash my phone FS & Main, clear user code and reset call time with finalization in one operation After that i can check simlock CID49,51 with a second credit Let me know if i'm right or wrong so i can start using kkclient |
Yes i think you are right. First Main+Fs, Finalization, Clear User Code. After that with second credit Simlock 49,51. |
i did like i thought but the clear usercode didn't happen! total call time did reset. Now i onley have one credit, can i remove the simlock now and remove the usercode later? why didn't the user code clearwhil i was checked?? Anyway i'm gone sleep now, thank for the help! |
User Code after resetting should be now 0000. Did you try ? |
Yes i tried 0000 and 00000000 and 1234 ... I think its a bug that i could select clear user code and finilization and fs&main. i tried it again and it all depens on the order you select. select reset call time, clear user code, finanization, FS and main all can be selected! But is you unselect Finalization you can't select it back... Seems that it will cost 3 credits for all i want to do. I should have bought 5 credits instead of 2, kulankendi if you let me but 3 more credits for 16€ it would be great if not np but let me know please(would be like if i bought 5 for 30€ because i already bought 2 for 14€ as i toutgh 2 would be enough) |
I just bought 5 more credits, i cleared the user code... ok I did simlock cid49,51 and i get message no more credits ... wel ok guess i have to wait but now my phone doesn't start up! wil it be ok when i do the simlock cod 49,51 again when i get the credits??? |
I seems KKclient cant even read info now! what do i do?? |
ok sorry for the spam but i tried it again and kkclient can read info now but phone still doesn't power on! |
You don't have credit and you try to unlock it rigth ? Don't worry, when you get credit and unlock it again all will be ok. |
Great it works, Conclusion 3 credits needed for all those operations |
is it possible to reset code of w200i without logger , i mean is it free to reset user code??? |
