07-02-2008, 19:03 | #1 (permalink) |
Banned Join Date: May 2006 Location: france
Member: 270730 Status: Offline Thanks Meter: 67 | F490 Freez i have this f490 freez i test 1.60 unlocker phone unlocked but phone freez and code reader 2.53b Phone info: ~~~~~~~~~~~ Phone Model: F490 Revision: F490AFHB3 IMEI: 3515780********* Phone lock password: 00000000 SIM lock password: 00000000 Connected to server Unlock codes: ------------- UNLOCK NETWORK LOCK: #7465625*638*70474274# Enter codes WITHOUT simcard inside the phone. You can check the current lock status using this code: *#7465625# whats solution |
07-03-2008, 04:54 | #3 (permalink) |
No Life Poster Join Date: Sep 2004 Location: Aunlock Age: 43
Member: 80354 Status: Offline Sonork: 100.1577575 Thanks Meter: 21,659 | use EU 3G Direct Unlocker online code reader latest version 1: connect combo cable to phone 2: set port1 for Samsung CDMA Modem and Port2 for COM port 3: power off the phone, then power it on 4: when phone start power on, it will be directly detected by your PC,before it show "phone freeze" click "START" button phone is unlocked this trick is to unlock phone when it start power on and detected, before it show "phone freeze" message in the screen, |
07-06-2008, 16:57 | #7 (permalink) | |
Crazy Poster Join Date: Jun 2008 Location: |ALGERIA|
Member: 786480 Status: Offline Thanks Meter: 19 | Quote:
other method i use it see at port manager wer you see phone detcted then quickly star unlock not user ""code reader"" whose Z170 repeat this step i unlock more F490 freezed phone good chance | |
07-06-2008, 18:44 | #8 (permalink) |
Member: 80354 Status: Offline Sonork: 100.1577575 Thanks Meter: 21,659 | Last Solution for your's Problem, we need to this Phone for Test, can you like share this phone, Kindly Check: more info http://forum.gsmhosting.com/vbb/showthread.php?t=552486 Thanks for Understand !!! |
ASK - RPL can unlock F490 FREEZED phone? | hoang | SPT BOX | 4 | 08-22-2008 16:03 |
F490 Freeze Not Detected | GHOSTMAN10 | Easy-Unlocker | 4 | 07-29-2008 09:21 |
F490 freeze | GSMBOURGES | Easy-Unlocker | 30 | 07-17-2008 21:24 |
F490 Freeze | GHOSTMAN10 | Easy-Unlocker | 1 | 05-14-2008 17:57 |
