f480 freeze can't unlock help i read all posted asme phone with some sw v Phone info: ~~~~~~~~~~~ Phone Model: F480 Revision: F480AOHE4IMEI: 351872027880704 SIM lock password: 0000 Connected to server Unlock codes: ------------- No unlock codes available! ------- Phone info: ~~~~~~~~~~~ Phone Model: F480 Revision: F480XXHF7IMEI: 351872027880704 SIM lock password: 0000 Connected to server Unlock codes: ------------- No unlock codes available! -------------------------------------- Phone info: ~~~~~~~~~~~ Phone Model: F480 Revision: F480JPHG3IMEI: 351872027880704 Phone lock password: 00000000 SIM lock password: 00000000 Connected to server Unlock codes: ------------- No unlock codes available! -------------------------------------- Phone info: ~~~~~~~~~~~ Phone Model: F480 Revision: F480XEHF3IMEI: 351872027880704 SIM lock password: 0000 Connected to server Unlock codes: ------------- No unlock codes available! ----------------------------- if use dirct unlock phone Phone info: ~~~~~~~~~~~ Phone Model: F480 Revision: F480AOHE4 IMEI: 351872027880704 OK - Phone unlocked |
Try with older Samsung 3g direct unlocker, 1.60, working 100%. |
yes, please do direct unlock and post here result!!! |
th 4 reply Ja\/\/aD 3 Attachment(s) Ja\/\/aD i check phone locks phone unlocked but problem phone freeze this my problem and already posted direct unlock th |
no unlock code available, mean ur phone is already sim unlocked, if u can see phone lock state, u will found them disabled. so i think ur phone dosn't accept any sim instead of the original one. this sometime happen in samsung qualcom model, but solved after Flash. i suggest to u to flash phone , and ur problem will be solved. br:) |
hi BouRRi_GSM if you can see first post you can see i flashed phone some sw v soo flash phone dosenot help good by and rh 4 you |
use rocker dongle OR ust pro fast direct unlock option it will fix ur prob B.R |
makave i tested ust also dosenot help |
So still have rocker option |
hi SJS also tested th 4 you |
i u have original sim card, plz try with it to be sure what's wrong with phone. also try with test card if possible. have u tryed to flash the boot file comming with this flash version u already used (F480XXHF7)? cause this happen to me not specially with F480 (phone sim unlocked but not accept any sim card), and solved by Full Flash (Ordinary flash including Boot file). anyway, i think other tool will not help u in this case. br:) |
try to flash the phone to another version then u can unlock the phone |
GO TO TIS THREAD http://forum.gsmhosting.com/vbb/show...highlight=F480 AND DO STEP BY STEP AND YOUR PFONE UNFREEZED |
