F700 is it suported or not to unlock ? Hi, There is no post about F700 and I have one to unlock. When it will be supported ? thks |
Well this model has not checked by us already, if you want, you can try by reading codes, the much you can get is CODES or Wrong result but youīll never damage phone by reading so... LETīs TRY IT !!! and post results. Best Regards !! |
When I have one I will try and post result. Thks |
here some info Phone info: ~~~~~~~~~~~ Phone Model: F700 Revision: F700AMGJ8 IMEI: 358444010****** Reading data from phone... ERROR - Can't get CRYPTKEY! p.s. have used combo e210 l760 self made cable hope this is the problem :D |
Please POST SCREEN SHOT, may be you have something wrong in your selection, by posting SCREENSHOT we could help you otherway impossible. Regards !! |
1 Attachment(s) here is the screen shot |
Please select as ZV60 and use correct ports, also check that your modem is not installed in a port upper than #19 Try and post results please. Best regards !! |
there is no modem found even with original usb cable will not found a modem just if i start the phone in download mode and use original usb cable |
Man you have not USE the USB ORIGINAL CABLE but the USB+RJ45 Combo CABLE for V809 YES, so use this cable and post results !! Regards !! |
well i have ordert the cable in feww days i will tray and post |
Ok, keep tuned friend. Best Regards !! |
@ aErOm and about my problem with dongle easy unlocker ! any solution or i must post here screen shoot too ? 10X |
Douhal Iīm looking up your problem, itīs different you know... Donīt press me PLZ. Thanks for comprenhension and Best regards !! |
