No Server No Server Server Off Pls Check Phone info: ~~~~~~~~~~~ Phone Model: A737 Revision: A737UCGI3 IMEI: 359673012140449 SIM lock password: 0000 ERROR - Can't connect to server! Check your internet connection or try again later... |
I have the same problem. Phone info: ~~~~~~~~~~~ Phone Model: A707 Revision: A707UCGD2 IMEI: 355458015908180 Phone lock password: 5650 SIM lock password: 0000 ERROR - Can't connect to server! Check your internet connection or try again later... |
I finished the phone using Direct Unlock function, you can try that also. Procedure here: http://forum.gsmhosting.com/vbb/show...4&postcount=52 |
Just use "Samsung 3G Easy Unlocker.exe" instead of "Samsung 3G Easy Unlocker Online Code Reader.exe" |
yes i'm ok with u but what's solution to get licence because i have formated my PC im confused with my customers :confused: |
what about phones without direct unlock procedure Phone info: ~~~~~~~~~~~ Phone Model: OT-C701/C701A Revision: Alcatel 010 03 IMEI: 3532050171***** Manufacturer: Alcatel if we have tool and we are not sure to be able to unlock phone so little interesting tool if can t use it plz solve that problem or make direct unlock for other models. ERROR - Can't connect to server! Check your internet connection or try again later... |
rahet 120mille ya kho... try to have always a copy of licence files and setup in a cd for cases like this |
always copy your all *.lic files from C:\Program Files\EasyUnlockerBox to safe place (cd/dvd/inbox) |
thx mate problem solved by your method |
Atleast Server OK Today http:///vbb/showthread.php?t=545707 |
Today ok Phone info: ~~~~~~~~~~~ Phone Model: L760 Revision: L760BUGH1 IMEI: 3566030******** SIM lock password: 0000 Connected to server Unlock codes: ------------- UNLOCK NETWORK LOCK: #7465625*638*15853840# Enter codes WITHOUT simcard inside the phone. You can check the current lock status using this code: *#7465625# |
Thanx for sharing, always post here with screenshots http:///vbb/showthread.php?t=541778 |
