Problems with com ports on eu box I am trying to unlock samsung A707 with the EU box using the 3G online code reader. Port 1 should be samsung CDMA modem and 2 should be the usb serial port. I could only get these port options. COM1 (communications port) COM4(Lucent Win Modem) COM6(sphere GSM Fighter cable) LPT1(ECP Printer Port) When I tried with these ports I got the error message: Can't get CRYPTKEY:confused: |
in PORT 2 you must select the port where you have BOX CONNECTED, when you connect box to PC it creates COM VIRTUAL PORT based in the USB port, sometimes you use FIGHTER DRIVERS to recognize box, other times you get something like USB <-> COM or if you correct installed box with correct drivers just get a COM PORT NUMBER, check where is your case, that based in your words seems to be the SPHERE GSM FIGHTER CABLE and do jobs .... Is very easy, donīt worry. With my best wishes. |
Thanks for your help, how do you use the drivers to recognise the box? Thanks again. |
When it ask for Drivers, choose "Install the software Automatically" if there is compatible drivers, if it doesnt found, choose "install from a list or specific location". then browse the driver. And install "Samsung_USB_Driver_Installer". before unlock |
Finally I got my EU box to work. However, I now have problem with opening the software. I kept getting the message you need the license to activate. I have activated the remote client and got license but I still get the same message. Can anybody please help? |
you mean still you're face error "Can't get CRYPTKE" if i am right Please check few thinks i'm sure you're select wrong comport setting Like http://forum.gsmhosting.com/vbb/atta...7&d=1201284092 Please Select Right Com ports Like http://forum.gsmhosting.com/vbb/atta...8&d=1201284375 i hope after Right Com Port Selection your's Problem will be Solve if after that not solve Kindly post here Screen Shot (software) then we'll help you how you unlock correctly Thanks very much |
Problems with com ports on eu I still have problem getting the right com port- Samsung CDMA modem. I have tried to install the samsung usb driver where there are 3 files: samsung CDMA madem sansung mobile usb modem samsung pc studio which has 3 files-usb drivers- 1, 2. 3 Which of these do I need to install to unlock samsung A707? |
@Ayindeokin try to see me in my office if you're in Ibadan. You need a little training on this which might not be tottaly solved here with your level of understanding. Wa ri mi ki nso nto ma se. Adebam |
you need to install samsung CDMA modem PS: i am agree with adebam please try to read Post/Threads/manuals/ about how to use, how to unlock bla bla |
problem with com ports on EU Hello, i have installed the cdma samsung driver but it did not come up on the com port. however, the micrsoft scanner and camera started up.Thanks. ayindeokin |
All Reday Post On Fouram Read FAQ & Search |
problems with com ports on EU I have had this problem for some time and have searched for threads.I have not seen one that solve my problem. If you seen the thread, you can show me the thread I will appreciate it. Ayindeokin |
