Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Easy-Unlocker
Old 03-14-2008, 19:32   #1 (permalink)
Member: 295112
Thanks Meter: 31
samsung m610 unlock
What about m610 unlock? Can it be supported? thanks
PS> and lg kg130.....
need update
pls
Old 05-10-2008, 08:24   #2 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
Thanks Meter: 21,659
M610 unlock, use E210 cable and select X550,
remember only use the RJ45 not plug the USB part of the Combo cable for making this model,
Regards
Old 05-10-2008, 16:21   #3 (permalink)
BRANCO's Avatar
Member: 94920
Thanks Meter: 22
Regards
Yes! I did everything as you say, but with X550 not have connected phone, with E250 phone is connected, but can not pass security MSL. This is bug!!!
I have tested 5 phones, always same thing!
What is it?
Old 05-11-2008, 16:33   #4 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
how to unlock, please post screen shot our other info about this, then we able to solved your problem
Old 05-13-2008, 02:04   #5 (permalink)
BRANCO's Avatar
Member: 94920
Thanks Meter: 22
1. Run Sam2G_EU
2. Selecte X550
3. Cable E210 but only RJ45
4. Conecte cable, phone power by on is alone
Bypassing MSL security... (Press PWR ON on phone)
ERROR - Can't connect to phone!
Port: SphereGSM Fighter Cable
Speed: 921600
Old 05-13-2008, 03:30   #6 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
possible reasons:
your phone ON, you are try to unlock
your cable is not good (check cable)
your phone jack is not good (check phone Jack)
remove cable from phone, after press job(unlock)
then connect cable and press power button from phone,
PS: where is screen shot ???
Old 05-23-2008, 01:05   #7 (permalink)
SM4RTBOY's Avatar
Member: 92326
Thanks Meter: 205
some problem E210 too !
tryed..
x550
c170
etc etc
sm4rtboy
Old 05-23-2008, 11:51   #8 (permalink)
shahzaadbutt's Avatar
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,421
please we need screenshot for help, post screenshot please
Old 05-23-2008, 17:49   #9 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
@SM4RTBOY really need good support ?
always post screen shot with your's problem
Old 05-24-2008, 08:13   #10 (permalink)
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,421
tryed..
x550
c170
etc etc
sm4rtboy
try to full eeprom reset and then try maybe help, *2767*3855#
Old 05-27-2008, 10:10   #11 (permalink)
chahin's Avatar
Member: 778985
Thanks Meter: 8
I had alot of similar problem, the solution was always the comp port, try to change the com port before any other thing, if not working post screen sh to the supporter and he will solve the problem.
Old 05-27-2008, 11:14   #12 (permalink)
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,421
maybe he have solve his problem
Old 11-19-2008, 13:21   #13 (permalink)
Cheater -Don't Deal with him-
Member: 21296
Thanks Meter: 328
I can't succeed to unlock a single M610 with eubox.
Old 11-20-2008, 15:28   #14 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
can you post here how you try to unlock?
Old 11-21-2008, 00:37   #15 (permalink)
BRANCO's Avatar
Member: 94920
Thanks Meter: 22
EU dont work with M610!
SAMSUNG SGH-M610 unlock done using HWKuFs micro!!!! arnold montes Samsung Flashers, Software, Firmware. 0 07-08-2009 09:54
Can i unlock samsung M610 Mounir UST Pro II 19 04-13-2009 22:20
Samsung SGH-M610-Unlock code telcentro Samsung Flashers, Software, Firmware. 16 01-06-2009 00:38
how ca i unlock samsung m610??? nowarno SYSOL Platform 0 12-11-2008 22:13
Samsung M610 unlock? mp3hot NSPRO 13 10-31-2007 23:09
Page generated in 0.21356 seconds with 9 queries
