01-25-2007, 01:07 | #1 (permalink) |
Registered User Join Date: May 2006
Member: 274461 Status: Offline Thanks Meter: 17 | L7 (r4517_g) - 0a20 Not Supported Why L7 (R4517_G) - 0A20 but it says ERROR : NOT SUPPORTED MODEL/BOOTLOADER WHY? |
01-25-2007, 02:10 | #2 (permalink) |
Member: 274461 Status: Offline Thanks Meter: 17 | OK i made a flash usin rsd.. now phone can power on..... BUT it wont complete power.. it only says hello moto and turn off.. its a pds damage as i see.. i need an answer.. is this model really supported or no.. and can someone tell me anyway to fix this without cutin shield help please.. |
01-25-2007, 08:12 | #3 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | alwase read sticky post.. http://forum.gsmhosting.com/vbb/showthread.php?t=366204 select correct model enter blank = for making blank repair = pds repair leve blank = remove blank from phone write full flash 1ff |
01-25-2007, 17:03 | #4 (permalink) |
Member: 274461 Status: Offline Thanks Meter: 17 | so.. i read it.. it is supported.. as i see.. thats sad =( my L7 is dead now.. always try to power on but always turn off.. in hello moto screen and when y try to flash always get error in like 19% of the process.. why ? |
01-25-2007, 17:37 | #5 (permalink) |
Member: 274461 Status: Offline Thanks Meter: 17 | when i do full flash see error!!! Split input file in codegroups: Processed ok Establish connection to handset FLASH Interface established ok Sending RAMDLD to handset RAMDLD started ok in handset Erase flash... Flashing codegroups ... Flashing codegroup 'cg0.smg' to 10092000 Flashing codegroup 'cg1.smg' to 100920C8 Err no: 01150004 Err no: 01120008 Err no: 01240004 please helop!!! |
01-25-2007, 18:12 | #7 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 420649 Status: Offline Thanks Meter: 414 | Do this: Use MotoRocker v1.13 !!! Connect USB cable from phone DIRECTLY to PC and not in UBL USB port !!! Select correct phone model (L7 R4517) Enter Blank Repair Leave Blank Post here FULL log of operation, even if you receive any error. |
01-25-2007, 18:20 | #8 (permalink) |
Member: 274461 Status: Offline Thanks Meter: 17 | ok.. when im trying to leave blank the first thing i get is this Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 7000 ERROR: Not supported Model/Bootloader! i tried again and blank left fine Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0300 Try to load backup file Sending RAMDLD to handset Power down handset but problem i have now is phone code sig error.. |
01-25-2007, 22:18 | #12 (permalink) |
Member: 420649 Status: Offline Thanks Meter: 414 | Here is attached. But can you please tell us what box you used with this phone? We just find this thread (in old Ultima forum): http://www.unlockforum.net/showthread.php?t=1981 |
01-25-2007, 22:25 | #13 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: JSR, BD
Member: 310155 Status: Offline Thanks Meter: 1,313 | Quote:
The Following User Says Thank You to reaz.com For This Useful Post: |
01-25-2007, 22:45 | #14 (permalink) |
Member: 274461 Status: Offline Thanks Meter: 17 | i used.. UBL... and not ultima... the problem is this.. i was unlocking the phone.. when it unlocks done.. and it tried to leave blank say.. model no and bootloader no supported.. then the phone was in blank.. all i did is flash it with a mosnter pack using rsd.. and the phone powers on.. but only in hellomoto screen and fastlly turn off.. i tired to search in other forums cuz i was workin with the L7 with itunes for like 6 hours.. and no reply i get.. from the support.. is this bootloader and model supported or no? |
01-26-2007, 07:05 | #15 (permalink) |
No Life Poster Join Date: Nov 2002
Member: 18041 Status: Offline Thanks Meter: 2 | i had exactly same problem with same phone and same bootloader ...in last stage of unlock process soft said bootloader dont supported ..then phone was killed ..then i set phone in blankmode next repair pds next leave blank mode ...i flashed with 1 ff now phone pwr up but freese in motorola logo with small legend in middle of screen ..small legend say PANIC ........................HOW CAN I SOLVE THIS ?? HELPPPPPP |
U400 not supported - why? | robbie | VygisToolbox | 3 | 11-26-2008 19:24 |
resume not supported why? | New Style | Universalbox | 1 | 08-20-2008 06:47 |
why rh-93 v6.46 is not supported why??? | kamo44 | HWK | 8 | 05-19-2008 23:49 |
L7 (R4513_G), ERROR: Not supported Model/Bootloader! | jose miguel | GOT Motorola | 2 | 01-23-2007 22:01 |
why there's not support why ?????????????????????????????????????????????????? ? | patric | TOTAL MultiServer | 4 | 07-09-2006 07:59 |
