08-04-2007, 06:55 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 52
Member: 54993 Status: Offline Thanks Meter: 47 | C139 Connection problem with NEW USB CABLE I have purchased new USB cable for ODM phones from my reseller. Still I get the same connection error with COM CABLE also. I am confused what to do. The cable was purchased for unlocking C139, C117 but failed with this cable. UBL team please guide me. I've installed cable driver, changed USB ports, ReInstalled Motorocker 2.17 and still the problem persists. Also my friend want to purchase UBL but due to this problem I am not able to recommend him. early reply will help me a lot. Thanks. Regards........... |
08-04-2007, 07:04 | #2 (permalink) |
No Life Poster Join Date: Aug 2006
Member: 337450 Status: Offline Thanks Meter: 718 | All ODM phones i encountered is not good in UBL, maybe they need to be update....Try to use t191 cable but surley you'll got error....no usb on c139.....correct me if im wrong... |
08-06-2007, 15:54 | #3 (permalink) |
Member: 54993 Status: Offline Thanks Meter: 47 | The error I get is, Phone should be powered OFF Open serial interface COM5 Please press and HOLD power ON button Error: 40010205 Error: 40110103 Please reply......... Regards........ |
09-08-2007, 17:40 | #5 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Ecuador -Andes
Member: 331361 Status: Offline Thanks Meter: 155 | you check version of phones (#02#), you serch line with "sw:" if your version is over 2.2.xxx it is not problem conection is the new version of acer base with rsa |
09-09-2007, 08:45 | #8 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: ALGERIA, Tlemcen, Tounane Age: 37
Member: 135039 Status: Offline Thanks Meter: 1,486 | Quote:
hi c139 c140 140c and other like c115 c116 not work on this speed and the stable speed working in this model is 115000bps and you can use a rs232serial and t191 cable not enter the jack completly test and post result | |
Problems with e1000 USB connection | haddar | Motorola P2k | 0 | 07-15-2006 15:20 |
Let's talk about C115 and C139 connection problem! | ionelka | Infinity-Box | 4 | 01-24-2006 08:36 |
connection problems with my data cable and nokia 6600 | kww2k4 | WD2 & APE (Symbian Phones) | 5 | 06-17-2005 20:22 |
Problems with C350 USB connection! | TDWiZ | Motorola P2k | 14 | 05-18-2004 21:03 |
cable-connection problems with T2x & R3xx | Tigerente | Old Ericsson Phones & Sony Phones | 6 | 07-14-2001 16:04 |
