Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Ultima Box Light
Old 10-02-2007, 05:43   #1 (permalink)
rk19801's Avatar
Member: 238252
Thanks Meter: 81
How To Unlock V3r
I M Using Ultima Box Light But I Cant Unlocked To V3r Pls Help Me For Unlocked Handset.
Old 10-02-2007, 05:59   #2 (permalink)
Member: 335021
hello my friends, you need make test point...
Old 10-02-2007, 08:39   #3 (permalink)
Member: 310155
Thanks Meter: 1,313
try this................
power on in flash mode(*+#+on)
conect with cable to pc
press ENTER BLANK (do that say as on software). now ur phone is TP mode.(phone is dead)
press unlock. after complite unlock press LEAVE BLANK to alive ur phone.
thats all.........................................
Old 10-03-2007, 04:56   #4 (permalink)
rk19801's Avatar
Member: 238252
Thanks Meter: 81
thanks friend
hi all do this all method but not its not solved pls give me unother solution that help me
Old 10-04-2007, 20:07   #5 (permalink)
Pecel's Avatar
Member: 123230
Sonork: 100.113333
Thanks Meter: 14
What's ur phone bootloader version? Did u read manual ?
Old 10-05-2007, 02:31   #6 (permalink)
Member: 70652
Thanks Meter: 2
If u'r bootloader version is OA.52, just use the magic test point, and put it to LCD conector, press and keep RED button pressed, connect USB cable, and release RED button
READY!!! Your phone is in test mode then press unlock. Simple...
Old 10-05-2007, 08:49   #7 (permalink)
Member: 118601
Thanks Meter: 200
"""If u'r bootloader version is OA.52, just use the magic test point, and put it to LCD conector, press and keep RED button pressed, connect USB cable, and release RED button
READY!!! Your phone is in test mode then press unlock. Simple..."""
did using magic TP need to be done with battery connect or not?
Old 10-05-2007, 14:19   #8 (permalink)
Member: 482218
Thanks Meter: 119
theres are way to make tp without battery, theres some kind of usb cable desgined for testpoint which sends a little more volts. if u have this cable try it without battery. also u can use easy tp cable from ubl, charges phone directly.
How to unlock V3R - by Viru viru Motorola P2K (USB-Smart) 40 07-11-2011 13:36
How to unlock V3r ufo_all Motorola P2k 8 05-13-2008 21:18
How to unlock V3r bootloader 0A.52 ! lv99clck Ultima Box Light 19 10-19-2007 12:25
How to unlock V3r and L7????? squall82 Motorola P2k 2 12-01-2006 07:58
How To Unlock V3r With P2k Easy Tool ::gsmcoder:: Motorola P2k 0 07-26-2006 19:56
Page generated in 0.17519 seconds with 9 queries
