SLVR L6 Dead Help neded Pls help hi can anyone help me with this I downloaded all software and Drivers and did everything like afsal said in his thread. Got software recognised my phone and i did everything went lik it said until the point when it says Started unlocking sequence Software struck like that for 12 minutes. did not respond So i had to close the software but since my phone was in the midway to unlock now its not powering on. It was struck at start unlocking sequence. Now the screen is blank. Can anyone suggest ways to repair the phone? i did not even do backup how to power bac the phone to normal.I really appreciate your help. Thanks in adavnce thanks http:///vbb/images/buttons/report.gif http:///vbb/images/misc/progress.gif http:///vbb/images/buttons/edit.gif |
try to conect it again to the sw and make unlock again. br |
I just had the same problem, take this steps to recover and unlock your phone: 1. Repair Tab --> "Remove Blank Mode" 2. Repair Tab --> "Set Blank Mode" 3. Repair Tab --> "Repair PDS" 4. Repair Tab --> "Remove Blank Mode" Now your phone must be unlocked! BR jepetu |
Hi I tried to repair it But the software is not recognizing my phone All drivers are installed since it recognizes my other Moto SLVR L7 but not SLVR L6 |
Try to connect the phone with the *+# keys pressed, sometimes it gives an error saying "usb device error" or something, if that happens just unplug and plug again the usb connector until the PC recognice the phone. BR |
yes, i have the same problem with l6 :( , is stop at SENDING RAMDLD to handset.... i cant make : - remove blank mode , stop @ SENDING RAMDLD to handset.... |
yes, i have the same problem with l6 :( , is stop at SENDING RAMDLD to handset.... i cant make : - remove blank mode , stop @ SENDING RAMDLD to handset.... sorry for 2 post... but bad conection to the internet |
yes, i have the same problem with l6 :( , is stop at SENDING RAMDLD to handset.... i cant make : - remove blank mode , stop @ SENDING RAMDLD to handset.... - set Blank mode, stop @ SENDING RAMDLD to handset.... - repair ... i have the same error i can't write boot or flash. I try with tp and nothing. GOT is not capable to revive L6.... :( the same bug like USB-SMART-MOTOROLA... |
