Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SagMaster Team OLD Products > SagMaster
Old 07-05-2007, 09:40   #1 (permalink)
Member: 92483
myc2-3 - ERROR: CHECK TEST POINT!
used SM_II_V18.07R
Found Phone, Phone Info:
- Phone Type: myC2-3
- Phone FW: JA3,WE: 041005 1452
- Phone HT : D0 07 01
- Phone IMEI: 35908400xxxxxxx
- Phone Code: 00000000 (inactive)
- MCP Flash ID: 00 01 22 7E 22 0A 22 01
- Chip(0): AMD 29DL320G 32Mbit
All testpoints checked and ok! Wires shorts.
What to do?
Old 07-21-2007, 13:11   #2 (permalink)
Member: 2321
i get the same message on myc2-3 need help
Old 07-21-2007, 13:21   #3 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
D Messages Is Right If U Have Tp Connections Fails ..used Another Test Jigs..clean Ur Pcb..
Old 08-07-2007, 10:28   #4 (permalink)
Member: 324833
Thanks Meter: 3
Test point error
Try to use another test point . By the time you try like 3 different test point I am sure one will work . and if none work , try and get the Picture of test point and sold the wire directly to the board . with this your prob. will solve
Old 10-05-2007, 22:30   #5 (permalink)
crusher's Avatar
Member: 8023
Thanks Meter: 13
I tried and soldered directly to board according to the support images, the result is the same.
myC5-3 - ERROR: START LOADER FAILED! CHECK TEST POINT! Vansy SMTi 13 07-09-2009 17:34
myC2-3 CHECK TEST POINT blinet SCDR II 1 10-25-2007 16:28
Myc5-3 Error: Check Test Point! services_mobile SCDR II 12 07-02-2007 20:24
Error: Start Loader Failed! Check Test Point! astralis SagMaster Team OLD Products 14 05-16-2007 18:55
always - ERROR: CHECK TEST POINT! laythjg09 SMTi 2 04-22-2007 14:24
Page generated in 0.16151 seconds with 9 queries
