01-23-2007, 09:38 | #1 (permalink) |
Freak Poster Join Date: Dec 1999
Member: 793 Status: Offline Thanks Meter: 1 | can't flash v65 by sagmaster I set 'direct write' but got message ERROR:CHECK TESTPOINT. I turn phone on and read codes - testpoint ok, codes ok. I try to flash it in ON state but got ERROR: PHONE IS ALIVE DON'T USE DIRECT WRITE OPTION I uncheck 'direct write' option and got error WRONG IMAGE How to flash it? In old sagmaster there was option 'don't read phone"..... |
01-24-2007, 09:05 | #3 (permalink) |
Member: 793 Status: Offline Thanks Meter: 1 | I used 'direct write' option. Phone off. Start like dead phone. I use correct cable and TP adapter, because I can read codes when phone on. Everything right? But why I got ERROR:CHECK TESTPOINT? Option 'skip detection' in old SM allowed to flash myv-65 in powered state and I used it many times.... |
01-26-2007, 17:07 | #4 (permalink) |
Member: 793 Status: Offline Thanks Meter: 1 | and now myx3-2 too..... The same problem with myx3-2 Phone begin to flash ok, something went wrong and I was need to reflash it. I check "direct write" but always got "ERROR CHECK TESTPOINT" The same SM 18.01 and 18.02 versions. Now I have dead phone I can't even reflash it. What to do? Cable and connector are standard, bought with SM and checked for hundred phones Are you sure oprion "direct write" work correctly? Last edited by Vadim Kova; 01-26-2007 at 17:33. |
01-26-2007, 22:01 | #5 (permalink) |
Member: 793 Status: Offline Thanks Meter: 1 | More: when I push button PWR on phone and then try to write flash - I got ERROR:START LOADER FAILED! CHECK TESTPOINT! I checked everything, made very short wires, 10 sm long from SM to TP - the same result. What else? |
01-27-2007, 13:35 | #6 (permalink) | |
Freak Poster Join Date: Jan 2006 Location: somewhere
Member: 227038 Status: Offline Thanks Meter: 78 | Quote:
I have the same problem with myv75 in direct write Sans titre.rar now "SM" can't flash dead myv75 and myV65 but can flash them if aren't dead.And i am sour that my v75 have a sw problem. | |
Can't flash NEC 338 | angel25dz | NEC | 0 | 03-29-2010 12:25 |
i can't flash 6220c by cyclone | bahaqurini | Cyclonebox | 13 | 12-21-2009 14:41 |
I can't flash M600 by UST Pro !!! | vnsun | UST Pro II | 7 | 10-22-2008 12:55 |
flash v65 | llcoolr | ARM9 BASED M62 / M62+ | 0 | 07-04-2006 21:43 |
I can't flash 7650 by prodigy pls help??? | proxy_gsm | Federal One | 1 | 11-14-2003 14:31 |
