Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SagMaster Team OLD Products > SCDR II
Old 04-17-2007, 13:46   #1 (permalink)
tical's Avatar
Member: 43802
Thanks Meter: 36
SCDR II MY401X Security Code
Do you have to use TP to read the security code from this phone ?
if not how is it done. i do not see the MY401X models listed using ver 28.04a.
Please advise. Which cable to use. I have a cable label MYC-5W
Old 04-18-2007, 07:21   #2 (permalink)
gsminfo's Avatar
Member: 23714
Thanks Meter: 18,769
use cable only
All information about cables you see in software exe
SMT
Old 04-21-2007, 14:13   #3 (permalink)
tical's Avatar
Member: 43802
Thanks Meter: 36
Sorry, this is posted in wrong section. I have SCDR II. I do not see information about cable. only TP information. MY-401 is not listed. I only see MY400z. allways getting message, phone not found when that model is selected and the phone is on.
Please advise
Old 04-22-2007, 22:52   #4 (permalink)
nekbil's Avatar
Member: 60178
Thanks Meter: 30
hi use only cable and select 400x all be ok i have try it and work very fine
Old 04-23-2007, 01:03   #5 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
Thanks Meter: 21,659
tested 100% working
Old 04-24-2007, 13:16   #6 (permalink)
tical's Avatar
Member: 43802
Thanks Meter: 36
Which cable
I do not see 400x, only 400z. So i choose 400z. I am using the cable My-C5W..is the the correct cable ?
always getting this error
Old 04-24-2007, 15:34   #7 (permalink)
Member: 56311
Thanks Meter: 273
use able my c2 and selectt any model in sCRII software and check clear your code and click on read code
Old 12-09-2007, 21:55   #8 (permalink)
Member: 69250
Thanks Meter: 27
mon probleme c'est avec un nouveau telephone my 411x je n'arrive pas a lire le code du telephone ni avec smti ni scdrii
any idea
thanks in advance
[email protected]
Old 12-09-2007, 21:58   #9 (permalink)
Member: 69250
Thanks Meter: 27
sorry for last thread i wrote in frensh well
i ahve new sagem my 411x with phone code i try with smti and scdrii no way to read or clear this code any idea sagmaster team
i wait for solution emergency
thanks in advance
[email protected]
Convert Scdr V14 To Scdr Ii Here hummy ARM9 BASED M62 / M62+ 1 04-26-2007 09:17
MY C4 -2 display off after read code with scdr II ventoinhas ARM9 BASED M62 / M62+ 3 12-07-2006 23:35
i can't believe it !! SCDR II give me wrong code !!! chavrotti SagMaster Team OLD Products 0 06-06-2005 16:48
How to use SCDR II to get codes ? tical SagMaster Team OLD Products 5 03-26-2005 13:11
Page generated in 0.26066 seconds with 9 queries
