08-24-2011, 12:12 | #1 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 362622 Status: Offline Thanks Meter: 43 | my404x unlocking problem i want to unlock this my404x i follow the tp from support but the problem is when i connect all cables on phone board i put the battery then power on the phone until now ok the problem is when i connect the rj45 to smti then the phone comes off the probleùis when i connect he pin 1 and pin8 please any help |
08-24-2011, 18:47 | #2 (permalink) |
Member: 362622 Status: Offline Thanks Meter: 43 | dears i made mistake and now i detect phone but problem with tp Found Phone, Phone Info: - Phone Type :myX6-2 - Phone FW :L13,9E: 261006 0930 - Phone HT :01 00 05 - Phone IMEI :353100015219984 - Phone Code :0000 (inactive) - Prod. Code :287102206 - Board Type :m62+ - NOR Flash ID :0001 227E 2223 2201 - Chip [0] :AMD S29GL512NH/L 512Mbit Boot Method: "GP Device" Autodetect Operation Cost: - Clear/Set Net Code :FREE - Change Firmware :1 Credit P.S. GP Method Work Only USE "SMTi Virtual Port(COM0)" HS Method Clear User Code 1 Credit Look For Target ...Not Found! - MSG: CHECK TP! thanks for any help |
The Following User Says Thank You to amazir For This Useful Post: |
10-15-2012, 23:14 | #5 (permalink) |
No Life Poster Join Date: Jun 2005
Member: 154448 Status: Offline Sonork: not yet Thanks Meter: 50 | me too the same problem read info ok but when unlock the write this Look For Target ...Not Found! - MSG: CHECK TP! Found Phone, Phone Info: - Phone Type :myX6-2 - Phone FW :L13,9E: 261006 0930 - Phone HT :01 00 05 - Phone IMEI :353100015214*** - Phone Code :00000000 (inactive) - Prod. Code :287102206 - Board Type :m62+ - NOR Flash ID :0001 227E 2223 2201 - Chip [0] :AMD S29GL512NH/L 512Mbit Boot Method: "GP Device" Autodetect Operation Cost: - Clear/Set Net Code :FREE - Change Firmware :1 Credit P.S. GP Method Work Only USE "SMTi Virtual Port(COM0)" HS Method Clear User Code 1 Credit |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
