Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SMTi Support Sections > SMTi
Old 01-11-2008, 15:55   #1 (permalink)
Member: 531985
Angry My511x unlock : Read Phone info ...fail
Hi,
It seems that the beta version is not working well !
It recognizes the phone, it loads the certificate but fails at the "Read Phone Info" step... even with "Forced HS device" checked !
I have tried it many times...
HHHHHEEEEELLLLLLLPPPPPPPP !
Thanks in advance
Old 01-11-2008, 19:50   #2 (permalink)
DZStorm's Avatar
Member: 160204
Sonork: 100.113150
Thanks Meter: 2,843
@dominique34
Please retry with fully charged battery , thats's important !!
Old 01-12-2008, 10:57   #3 (permalink)
cover_one's Avatar
Member: 97299
Thanks Meter: 45
same problem here , battery is fully charged
Old 01-12-2008, 15:50   #4 (permalink)
Member: 531985
Second phone with same problem....
JOB "DETECT PHONE":
Found Phone, Phone Info:
- Phone Type: Sagem my511X
- Phone FW: EON,DC: 191107 1057
- Phone HT : 84 28 05
- Phone IMEI: 356*********740
- Product Code: 253030432
JOB "READ CODE":
POWER ON PHONE ...Ok!
- Load Certificate ...Done!
- Load Application ...Done!
Read Phone Info ...Fail!
Old 01-12-2008, 17:10   #5 (permalink)
riadh_tn's Avatar
Member: 21553
Sonork: 100.114141
Thanks Meter: 220
correct some new sagem have a problem for read info but its supported 100%
solution read flash .....and use read code from flash ..u will lost some time in reading flash but u will get your code for 100%.
Old 01-15-2008, 16:47   #6 (permalink)
Member: 531985
Thanks for the trick but how does it work ?
How do you read from flash ? There's no button with such a name !
Also, SMTi has a strange behavior. It uploads the flash through ftp to a server but nothing else happens.
So ?
Old 01-18-2008, 17:14   #7 (permalink)
riadh_tn's Avatar
Member: 21553
Sonork: 100.114141
Thanks Meter: 220
as i see you readed the flash yes server upload flash automtique its ather think but if the flash was correctly sended to ftp smti. then u will found the file flash located in smti/sended folder.
1-rund smti
2- browse dump button
3- select the file ( readed flle is sended folder)
4- sw will generat with server your code automatique.
5- tape your code and enjoy
Old 01-18-2008, 19:52   #8 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
1-rund smti
verry useful post thx radith..br
i have a probleme with bb5 phone, hwk cant read phone info corectly yassinek85 HWK 8 10-27-2009 04:58
Can't unlock even read phone info kg290 niket-shah ULT PRO 2 01-17-2009 15:57
M6100 problem... reading phone info slooooooowly and then Failed Burnt Cobba ThunderStorm Box 2 03-26-2007 13:58
sagem my401x unlocked read phone info KAITA SagMaster Team OLD Products 2 08-22-2006 06:39
DejanBOX works, but MBUS not read phone info. MP Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 19 02-17-2002 15:50
Page generated in 0.14987 seconds with 9 queries
