myX2-2 Connect phone ...Error! Read Phone Info ...Done Found Phone, Phone Info: - Phone Type :myX2-2 - Phone FW :JA3,LD: 240505 1035 - Phone HT :27 04 01 - Phone IMEI :35xxxxxxxxxxxxxx - Phone Code :00000000 (inactive) - Prod. Code :252100842 - Board Type :m62 - NOR Flash ID :0001 227E 220A 2201 - Chip [0] :AMD 29DL320G 32Mbit Get Code from server ...Success! - Net Lo code :32014263-76 - Net Hi code :42709738-32 - Connect phone ...Error! always i got this error,kindly some one guide me pleaze |
I think power suply some problem write code manualy - Net Lo code :32014263-76 - Net Hi code :42709738-32 SMT |
i gave power from power suplay about 5v same error appear any idea appreciated - Phone Type :myX2-2 - Phone FW :JA3,LD: 240505 1035 - Phone HT :27 04 01 - Phone IMEI :35xxxxxxxxxxxxxx - Phone Code :00000000 (inactive) - Prod. Code :252100842 - Board Type :m62 - NOR Flash ID :0001 227E 220A 2201 - Chip [0] :AMD 29DL320G 32Mbit Get Code from server ...Success! - Net Lo code :32014263-76 - Net Hi code :42709738-32 - Connect phone ...Error! |
put code by keypad SMT |
i tried only can enter 8 numbers i think counter is blocked no any other way? |
If yes ... Read manual step by step HOW to repair software problem ... manual SMT |
without sim card it says SIM fehht with sim card it says sim lock and can enter 8 gigit number will this flash work at this situation? thanks |
@helperer Correct word is "SIM FEHLT" = SIM is missing ! Try access phone with a Valid sim & then Press menu button followed by star(*) & hold , a menu will appear there's an option about sim lock see if you can put Net code there or not ! if not , your mobile need repair ! |
you are right can put the code but only 8 numbers cannot put last two numbers will it be okey when flash the mobile? thanks |
