12-21-2007, 14:18 | #1 (permalink) |
Freak Poster Join Date: May 2007
Member: 519206 Status: Offline Thanks Meter: 11 | my401C ...Unsupported! - Phone Type: my401C - Phone FW: LB5,QT: 190307 1204 - Phone HT : AA 21 05 - Phone IMEI: 353--------------- - Product Code: 252908574 Get Code from server ...Unsupported! Read 0x06000000 - 0x08000000... @ support , please add. Br |
12-22-2007, 12:25 | #3 (permalink) |
Member: 519206 Status: Offline Thanks Meter: 11 | unlock done !!! JOB "READ CODE": Found Phone, Phone Info: - Phone Type: my401C - Phone FW: LB5,QT: 190307 1204 - Phone HT : AA 21 05 - Phone IMEI: 353--------------- - Product Code: 252908574 Get Code from server ...Success! - Net code: 21671215-69 @ support ... thanks for fast action. keep it up ! |
12-24-2007, 08:50 | #4 (permalink) |
Member: 519206 Status: Offline Thanks Meter: 11 | Again another one done !!! JOB "READ CODE": Found Phone, Phone Info: - Phone Type: my401C - Phone FW: LB5,QT: 190307 1204 - Phone HT : AA 21 05 - Phone IMEI: 353--------- - Product Code: 252908574 Get Code from server ...Success! - Net code: 20274027-49 |
12-24-2007, 10:34 | #6 (permalink) |
Member: 519206 Status: Offline Thanks Meter: 11 | testpoint same as in support http://www.sagmaster.com/tp/index.php?pSel=63 but i did not use any resistor for this model as i will get "Found not found" with it. Choose My401c on sw and switch on with fully charged battery just wait few seconds for the phone to start and press "read code" directly, and sw will ask to remove battery ....... just follow . thats all. If on the first time you press read code and get phone not found, wait few seconds and press on read code again and again if needed !! sometime need to remove battery and switch on again ..... thats all and good luck |
12-24-2007, 11:38 | #7 (permalink) |
Member: 519206 Status: Offline Thanks Meter: 11 | Again another one done !! Found Phone, Phone Info: - Phone Type: my401C - Phone FW: LT5,QM: 150207 1727 - Phone HT : B0 20 05 - Phone IMEI: 353----------- - Product Code: 252861924 Get Code from server ...Success! - Net code: 20485503-99 |
01-02-2008, 18:42 | #8 (permalink) |
Junior Member Join Date: Jan 2005 Age: 54
Member: 106849 Status: Offline Thanks Meter: 0 | Found Phone, Phone Info: - Phone Type: my401C - Phone FW: LE5,QP: 160307 1338 - Phone HT : C0 22 05 - Phone IMEI: 35385901113xxxx - Product Code: 252849358 resulta unsyportad?????? message qui donne : POWER ON PHONE ...Ok! - Load Certificate ...Done! - Load Application ...Done! Read Phone Info ...Fail! Last edited by DZStorm; 01-03-2008 at 16:59. |
01-10-2008, 09:57 | #12 (permalink) |
Junior Member Join Date: Jun 2005 Age: 56
Member: 154137 Status: Offline Thanks Meter: 0 | Found Phone, Phone Info: - Phone Type: my401C - Phone FW: LR5,QP: 160307 1355 - Phone HT : 44 25 05 - Phone IMEI: 353859013240082 - Product Code: 252855819 Get Code from server ...Unsupported! |
01-11-2008, 06:38 | #13 (permalink) | |
Member: 154137 Status: Offline Thanks Meter: 0 | Quote:
K510i Unsupported chipset revision with Ultimate Unlocker | disskar2 | Cruiser Suite | 0 | 03-29-2010 16:38 |
k220 unsupported accessory | umarmsn | Sony Ericsson | 0 | 03-29-2010 15:57 |
my401c can be unlocked or not? | daced | ARM9 BASED M62 / M62+ | 1 | 07-17-2007 19:03 |
can i unlock sagem my401c in sagem dd? | zonetrichur | SAGEM JTAG UNLOCKER | 4 | 06-23-2007 21:21 |
