RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine |
04-02-2011, 09:38 | #1 (permalink) |
Junior Member Join Date: Feb 2010 Location: Netherlands
Member: 1242964 Status: Offline Thanks Meter: 5 | G86-730-A2 chip I cannot get any working chip. I ordered from two sellers on ebay and i ordered directly from a chinese electronics wholesale. All the same problem. The problem is that when i power on the notebook, the post screen appears but has big vertical bars with coloured stripes. After a few seconds the notebook switches off. When i reflow the original chip back on the board is works fine. However the original chip is not reliable so it has to be replaced. I have 3 notebooks i tested this on so it is not a faulty replacement of the chip. Can someone tell me what the problem can be. Are there different versions of this chip? (g86M or ?). Can someone give me a good seller for this chip. |
04-02-2011, 09:44 | #2 (permalink) | |
Crazy Poster Join Date: Mar 2007
Member: 473301 Status: Offline Thanks Meter: 11 | Quote:
04-02-2011, 13:53 | #3 (permalink) |
Member: 1242964 Status: Offline Thanks Meter: 5 | No, they are not bad, they are incompatible. I have 15 pcs. from 3 different sellers that all do exactly the same. Impossible! There must be an explanation. |
04-02-2011, 15:22 | #4 (permalink) | |
Crazy Poster Join Date: Dec 2010
Member: 1481034 Status: Offline Sonork: Halim_Xu Thanks Meter: 3 | Quote:
pls search for HONGKONG LRF COMPONENT INC LTD on web, they're specially produce video chip,chipset and ics | |
The Following User Says Thank You to Halim_xu For This Useful Post: |
04-02-2011, 16:11 | #6 (permalink) | |
Member: 1242964 Status: Offline Thanks Meter: 5 | Quote:
The reason why i replace them is because i know nvidea chips fail. But they fail in many different ways. (no screen, coloured dots, coloured stripes, no hdmi) But i cannot believe that this the problem. I think it might has to do with the version. (i.e for pc vid. card or for notebook) | |
04-03-2011, 20:05 | #7 (permalink) |
Member: 1242964 Status: Offline Thanks Meter: 5 | Here are some pictures to illustrate the problem Img 1 (post screen) Img2 (boot screen) Img3 (fail and org bga) Img4 (GPUZ info about org GPU) |
04-21-2011, 23:14 | #11 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 437621 Status: Offline Thanks Meter: 19 | Wow, certainly an issue, but let me clue everyone in on what happens in the used chip market. A big wholesaler will buy a large batch of defects, either wrong markings or bad lot from the motherboard assembly house. Then that gets distributed in smaller quanities to many suppliers. Then the market gets flooded with all these bad chips. It's ashame for us, but this is not an uncommon problem. even reliable sources get stuck with bad product. They don't throw them out they sell them hoping they will sit in someones inventory and never get used. This is the number one worst problem in our business. getting good product. Now. Monitron. Find some G86-731-A2 chips with 10 or 11 date code. They should be factory fresh. And try to stick with Taiwan and stay away from Hong Kong and mainland china suppliers. |
The Following User Says Thank You to Dan Collins For This Useful Post: |
05-03-2011, 20:43 | #12 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1219442 Status: Offline Thanks Meter: 1 | i postet it in an other thread....maybe usefull here to. i had a Sony Vaio Laptop with a g86-750-a2 gf8400m. I remove the chip ,reball and same results only some pixels. I found a g86-770-a2 gf8600m and installed it, now it works perfektly! Last edited by fahady112; 05-03-2011 at 20:53. |
08-04-2011, 20:29 | #14 (permalink) |
Junior Member Join Date: May 2011
Member: 1576270 Status: Offline Thanks Meter: 1 | g86-730-A2 Hello, anybody any solution for that issue from monitron ? Have the same with diferent g86-730-A2 from china, date code 07 and 08 Bekim here pictures http://www.albatronic.de/IMAG0780.jpg http://www.albatronic.de/IMAG0781.jpg |
08-22-2011, 23:24 | #15 (permalink) |
Member: 437621 Status: Offline Thanks Meter: 19 | Bekim, First pic looks like bad LCD or cable, but I know it isn't. Second pic is definetly video, but maybe video RAM not GPU. Tough call. Could be bad traces? Gut says its not the GPU if you replaced it with same results. But who knows, maybe same bad batch of chips. Buying from China is a real gamble. |
for a chip web-site | aliwali | GSM Mobile Links | 0 | 12-16-2001 04:28 |
N5110 what chip is COBBA? | asas | Nokia Hardware & Hardware Repair | 7 | 08-12-2001 22:13 |
circuit diagram for mbus using flasher cable chip | palladine | Nokia Hardware & Hardware Repair | 0 | 06-26-2001 16:10 |
I need tia file for INTEL 28F800 B3-T chip. | SashaM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-20-2001 21:05 |
Pragramming 5110 - 24c16 chip | xPumpa | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 11-21-2000 23:28 |
