RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine |
![]() | #181 (permalink) |
Major Poster ![]() ![]() Join Date: Apr 2010 Location: Scarborough, United Kingdon. Age: 55
Member: 1285693 Status: Offline Thanks Meter: 5 | I have made a tool for removing it from a double ended dental pick. I bent the pointed tip a few mm then filed it flat so its thin enough to fit under the chip. I did each end the opposite side so the same tool can do the left hand or right hand side of the chip. I used 1500 sand paper and microscope to make sure the edges weren't sharp enough to damage the BGA chip. I will upload some pictures if anyone is interested as I may not have described it very well for some. I either use a hot air pen or on the jovy depending how much there is. You rarely get it all. When I suspect a chip still has epoxy under it i use more lower heat and lots of flux. Any epoxy around the balls makes them significantly harder to reflow as the epoxy insulates them sometimes to the point where they need more heat than the chip can take. Try and maintain a steady reflow temp a bit longer before you try and pull the chip (not easy with IR). The epoxy dis-solvers don't really work that well. If anyone has better methods of removing the epoxy I would love to hear from you. |
![]() | #182 (permalink) | |
Member: 1285693 Status: Offline Thanks Meter: 5 | Quote:
![]() | #183 (permalink) |
Member: 1285693 Status: Offline Thanks Meter: 5 | Has anyone tried "Low Melt" made by Zeph? Low Melt DeSolder Wire, Low-Temp SMD De-Soldering Removes Chip Quick & Easy I really think you should check this out, especially for cleaning the BGA chip and site. Ive contacted them to see if they have any success im getting it under a BGA. A paste version of this would be amazing. |
![]() | #184 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2007
Member: 437621 Status: Offline Thanks Meter: 19 | I use the low temp solder all the time for SMD componets, connectors, and flat packs. It is not possible to use it under a BGA. Its like working with a ball of mercury. I can't see any way to get it under the bga. Besides the existing solder has to get to liquid state and blend with this low melt stuff. As far as the epoxy goes. A dental pick and a lot of patience is the only method I have found to work. I use BeauTech SH216 pick and a hot air pencil. Fits nicely under the BGA. Adding extra lower heat helps too when removing the BGA. The BGA's larger than 25mm are much harder to remove |
![]() | #185 (permalink) |
Member: 1285693 Status: Offline Thanks Meter: 5 | I can see it making a massive difference to site cleaning and chip cleaning and got confirmation back from zeph thats it's no use to removal. Ive tried similar methods in the past like using lead solder paste and running under the chip and it just beads out. |
![]() | #189 (permalink) |
Member: 437621 Status: Offline Thanks Meter: 19 | I am going back to the original topic because I found something new that affects the Nvidia, or any chipset, to overheat. I have noticed a big increase of overheating issues with laptops running Windows 7. I have found that the ability of changing the minimum processor state to a high value is burning out these laptops. Almost every one of these I have repaired have the minimum value set to 100% instead of 5%. This causes the CPU to stay at the maximum settings causing overheating issues very quickly. Windows 7 seems to be able to alter these settings automatically at some point which I have yet to determine why that is happening. Vista has the same power settings since SP1 but doesn't seem to change the settings like Win7 does. Has anyone else noticed that laptops with Windows 7 are an issue? |
![]() | #190 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1630325 Status: Offline Sonork: teccoelho Thanks Meter: 0 | ![]() Hello everyone I apologize if my English is not 100%, but you will understand ( i think ) i read all 13 pages of this thread and i'm happy with such good information, great website after that i decide register to share and learn more ( Dan Collins i like all your tips and skills you are very good thank you and all of you that post here tips about nvidia and temperature profile ![]() i have the zm-r5860c from Shenzhen Zhuomao Technology i know lot of you don't have same machine and this it does not matter, i just like share with all of you the temperature profile that i received from the manufacture engineer please check all temperature profile and give me all of your comments about it. The re-balling bga in my opinion is a learning that every day we learn more and more to achieve better results Halim_xu if you see this topic please share with me your profile i know you have the same machine with different profile i don't know why the seller provide this profile for you and the different for me ( my is provide by the engineer ) my ps3,xbox, laptops profile needed be adjust ![]() ![]() please i accept all comments, tips, anything that can grow my skills i also need suggestion of the temperature profile for xbox and ps3 please, i'm trying archive the best safety temperature to lift the gpu on both consoles thank you all . peace . i will be here every day to share, help and learn.. |
![]() | #191 (permalink) |
Member: 1630325 Status: Offline Sonork: teccoelho Thanks Meter: 0 | sorry for the double post but i cannot edit my last one here is my new temperature profile provide by the manufacture engineer , please check and let me know if i can keep this or need change. XBOX360 preheat1 top: 160 / time: 60 bottom: 165 / time: 60 slope: 3 preheat2 top: 190 / time:35 bottom: 205 / time:30 slope:3 activation top: 210 / time: 40 bottom: 255 / time: 30 slope: 3 soldering1 top:225 / time:90 bottom: 280 / time: 200 slope: 3 soldering2 ( don't need for xbox) only ps3 down: top 190 / time 30 bottom 190 / time 30 slope:4 |
![]() | #192 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2003
Member: 44625 Status: Offline Thanks Meter: 36 | Quote:
![]() | #193 (permalink) |
Member: 437621 Status: Offline Thanks Meter: 19 | Trion, This was on AMD based mobo's. Now I cannot vouch for the setting, but I have been seeing this on laptops that have been running high end gaming, which I do not reccomend for laptops, and believe the games are turning on performance features that Windows 7 seem to accomodate and earlier OS's didn't. What I am seeing is on these laptops that come in is the power settings set to max. The customers swear they didn't even know about the setting, but in every case it was high graphics games and Windows 7 that did it. I have found no way to fix this since Windows 7 allows ACHI control to these games. Customers don't like hearing that there are some programs that should not be used on these laptops. This is a real dilema for us repair guys. |
![]() | #194 (permalink) |
Member: 437621 Status: Offline Thanks Meter: 19 | tec2004, The zm-r5860c seems like an advanced version of the Bird 5000. Looks like it uses a combo of hot air nozzles and IR. I read the manual and it seems like it uses the full temp control capabilty of the module unlike the IR and BIRD which only has preset limited functions. Not sure I can compare or use your settings since my systems do not have that level of temp control. Did you get the camera option? Not sure that would be very useful unless it could see under the BGA. Maybe you could see when the BGA self aligns itself. That could be handy. Neat machine. Keep us posted as to your results. |
6210 flash chip problem??? | maciekmm | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-20-2004 18:21 |
6210 flash chip problem??? | maciekmm | Nokia Hardware & Hardware Repair | 1 | 10-19-2004 17:27 |
Panasonic GD67 source chip problem | corale99 | Hardware Repair by brands | 0 | 10-06-2003 07:19 |
Source chip problem on Panasonic GD67 | corale99 | Panasonic | 0 | 10-03-2003 22:30 |
GF768 flash chip problem | looker | Hardware Repair by brands | 0 | 03-08-2002 07:09 |
