RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine |
01-15-2013, 15:54 | #1 (permalink) |
Junior Member Join Date: Jan 2013
Member: 1868894 Status: Offline Thanks Meter: 0 | NVIDIA MCP67M-A2 Volt Mod via pencil or tiny dot of solder help Any way to have the video card share more than 128MB? I know for a fact it is a limiting factor. Once I got DDR2-800 and Overclocked my Turion 64 X2 TL-68 2.4Ghz to 2.6Ghz and the ram went up to DDR2-867 I got an instant 20fps increase just from the cpu overclock alone since the overclock yielded a lot more memory bandwidth. From 425Mhz to 555Mhz yielded an additional 10-15fps boost so all games are playable now. I can even run Unreal Tournament 2004 at 1280x800 and everything on as high as it will go at 35fps. If I could get a volt mod to boost it past 1.2v I could get 600-650Mhz out of this little puppy! I notice the 128MB of shared memory is performing quite well since my system memory bandwidth is so high. The PRIMARY bottleneck for resolution is the limit of 128MB of shared video memory. If I could boost the shared memory to 1GB I could get some decent resolution framerate since the 7150M in itself is not a bad gpu. I monitor gpu memory usage and at anything above 640x480 it's tacked to 100% on Insane 2. At 320x240 it uses only 80-90MB and I get like 40-50fps. So does anyone know which Hex string in the vga bios contains the information for the Shared Memory amount? Since there's an option in the BIOS and it's only 64MB or 128MB. I don't think it's impossible to change this amount. I'm waiting on a response from an Nvidia Engineer to give me more info. Thanks |
