02-20-2009, 22:06 | #1 (permalink) |
Freak Poster Join Date: Dec 2005
Member: 207515 Status: Offline Thanks Meter: 20 | Problem Unlocking U800 - Please Help all drivers installed with qualcom drivers, but get the below, tried many times. Searching for Ultimate-Sam please wait Clip found setting Update mode..ok ClipID=6******* Version :v2.17 phone lock set to 00000000 Phonelock disabled User-simlock set to 00000000 User-simlock disabled ********** Modem info ************* ModelName: CountryCode: SWVer: MemoryName:TY9D00A800BT(U200) IMEI : 356615020587601 Chipset info: M6260AKYRZ251032r ************************************ Reading SECURE DATA....ok Analyzing data..done ok failed proceeding.. Secure Authenticating.. |
02-23-2009, 22:47 | #3 (permalink) | |
Member: 207515 Status: Offline Thanks Meter: 20 | Quote:
Can you tell me where to get the unbranded Firmware and just a quick instuction on flash procedure...... i have had no luck with this Ultimate sam clip since i have bought it! BR | |
02-24-2009, 11:50 | #4 (permalink) |
No Life Poster Join Date: Mar 2007 Location: /Fr/Ch\Ro\ Age: 39
Member: 467911 Status: Offline Thanks Meter: 351 | U800XXHF3 you have here on forum or you google for it and the flasher ==> Multi Loader 5.32 or 5.33 etc |
The Following User Says Thank You to free1600 For This Useful Post: |
02-24-2009, 12:14 | #5 (permalink) |
Member: 467911 Status: Offline Thanks Meter: 351 | 1. Make sure you have FastMultiLoader v5.32 or v5.33, SGH-U800 flash file and the original samsung USB cable that came with the phone. 2. Connect the USB cable to your computer and install the USB drivers, unless they are already installed. 3. Remove the battery,simcard and memory card. Replace battery, Hold no.9 on keypad and press power button,Attach your phone to the USB cable, download" will be shown on your phone's screen. 4. Run the FastMultiLoader v5.32 or v5.33 5. Select the radio button, which lists MSM6275/MSM6280. 6. Tick Full Download then click Boot and select the boot files which are inside the folder containing the flash files 7. Click the Amss, Rsrc1, Rsrc2 and Factory FS buttons and select the appropriate files. Select (Low).r2c rather than (Mid).r2c. FOTA and ETC fields should contain no file. 8. Click the Port Search button so that the connected COM port is shown as Ready. 10. Click the download button on the FastMultiLoader v5.32 orv5.33 window. 11.When it's done it says "ok complete". 12.Unplug the USB cable, put the sim card and the battery back in and turn the phone on. It will initialise and restart by itself with the new firmware. To check your existing firmware type *#1234# into your handset. |
The Following 2 Users Say Thank You to free1600 For This Useful Post: |
02-27-2009, 01:08 | #6 (permalink) |
Member: 207515 Status: Offline Thanks Meter: 20 | Many thanks to FREE1600 for the advice, did manage to flash U800 with generic software, BUT still getting the below and cannot perform unlock Reading SECURE DATA....ok Analyzing data..done ok failed proceeding.. Secure Authenticating.. what else can i do and what does "failed proceeding.. Secure Authenticating" mean |
02-27-2009, 02:10 | #7 (permalink) |
Member: 467911 Status: Offline Thanks Meter: 351 | Sorry bro perhaps don't work for it (new version???) Have you ticked the bypass with MSLCODE ? and what cable you use try with E210 combo cable rj45 + usb ? and have pc studio mode activated in phone settings usb connection Perhapses someone can advice ??? br, free1600 |
03-25-2009, 16:33 | #10 (permalink) |
Member: 207515 Status: Offline Thanks Meter: 20 | Now more problem with U800 After Flahing new firmware U800XXHF3 to Sam U800 with flasher ==> Multi Loader 5.33 The fone does not respond after switching on, freezes on memu screen, 1st cannot unlock using ultimate sam, now phone software problem. problem after problem........ Also this is a brand new phone!! can anyone help!!!! |
03-28-2009, 15:52 | #11 (permalink) | |
No Life Poster Join Date: Jul 2004 Age: 37
Member: 347619 Status: Offline Thanks Meter: 78 | Quote:
and why did you flash the phone for unlock? you could have reseted the phone | |
04-26-2009, 00:17 | #12 (permalink) | |
1. Make sure you have FastMultiLoader v5.32 or v5.33, SGH-U800 flash file and the original samsung USB cable that came with the phone. 2. Connect the USB cable to your computer and install the USB drivers, unless they are already installed. 3. Remove the battery,simcard and memory card. Replace battery, Hold no.9 on keypad and press power button,Attach your phone to the USB cable, download" will be shown on your phone's screen. 4. Run the FastMultiLoader v5.32 or v5.33 5. Select the radio button, which lists MSM6275/MSM6280. 6. Tick Full Download then click Boot and select the boot files which are inside the folder containing the flash files 7. Click the Amss, Rsrc1, Rsrc2 and Factory FS buttons and select the appropriate files. Select (Low).r2c rather than (Mid).r2c. FOTA and ETC fields should contain no file. 8. Click the Port Search button so that the connected COM port is shown as Ready. 10. Click the download button on the FastMultiLoader v5.32 orv5.33 window. 11.When it's done it says "ok complete". | |
04-27-2009, 01:56 | #13 (permalink) |
Member: 467911 Status: Offline Thanks Meter: 351 | Hy mobcreations, if you power on the phone is freezes ? you can make a picture of the phone powered up? @gsm_zone perhaps you can help better if you have an idea ? I told him to flash the phone because I haved a issue like that and I flashed the phone and unlocked with the clip and worked for me br, free1600 |
05-07-2009, 10:01 | #14 (permalink) | ||
the problems that you can get when unlocking a qualcomm are bluetooth is on drivers are not installed correct or other software problems all can be solved by fully resetting the phone and reinstalling drivers you can also try using a combo cable Quote:
if you flash the boot the phone will die if its not compatible with the phone the only solution is flashing by jtag to revive your phone | ||
05-08-2009, 18:01 | #15 (permalink) |
Member: 467911 Status: Offline Thanks Meter: 351 | @gsm_zone I tried to help by msn and if i remember well i already asked if bt is on and etc ... the drivers gived a headache ...(i maked print screens for help) I know if you mess with the boot you can break the phone but i gived the link for the files that worked great for me with same phone ==>unbranded the phone and i unlocked with the clip |
problem unlocking cg300.... please help | ryumahon | VygisToolbox | 14 | 07-10-2009 13:23 |
Problem unlock 6120c Please help UB End credit GONE | ServiceTEL | Universalbox | 2 | 03-13-2009 13:42 |
Trouble unlocking U800, please help... | jdwe | UST Pro II | 2 | 02-25-2009 10:31 |
Problem to unlock 3250 please help... | drag | MT-BOX | 3 | 08-10-2007 14:59 |
Problems Unlocking ZV10 Please Help | mbcommunication | NSPRO | 5 | 02-26-2006 23:28 |
