Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Panasonic
Panasonic Panasonic-News...
Old 02-08-2002, 00:15   #1 (permalink)
Member: 8792
Unhappy gd35 killed
Hi, <br />can anyone help me, i just kill two gd35.<br />What can I do.
Old 02-08-2002, 00:21   #2 (permalink)
Member: 6114
Post
no solution<br />when one panasonic die, no solution then<br />i kill 3 pieces
when you flash/unlock the battery must be EVER full
spear
Old 02-08-2002, 05:16   #3 (permalink)
X-Shadow's Avatar
Member: 871
Thanks Meter: 602
Post
Hello,
There is no solution 'BY CABLE' if you erase the<br />boot loader in the flash. You must open phone <br />and reprogram the Flash IC inside it using <br />expensive Flash IC external programmers. Read<br />Flash of working phone and write it to dead phone.<br />After dead phone will have new boot loader, you <br />can now flash it again using cable only and also<br />change IMEI and restore RF settings using chkbox.
B.R.<br />X-Shadow
Old 02-08-2002, 11:02   #4 (permalink)
blutac's Avatar
Member: 7734
Hi,
Any idea where to get this expensive flash ic programmer? I have a lot of dead gd52 and gd35 phones waitin to be resurrected.
thanks <img src="smile.gif" border="0">
Old 02-16-2002, 03:39   #5 (permalink)
Member: 8491
Post
try to flash the damage phone with this metod:<br />need paralel cables for two phones,<br />WinMoDo+ ver.2.9,<br />Gad35u.rel file,<br />working phone<br />and damaged phone,<br />boot from working phone<br />need repeat procedure 3-4 ways.
Old 02-22-2002, 19:25   #6 (permalink)
Siemens man's Avatar
Member: 3925
Thanks Meter: 22
Post
hi Arielsat<br />-------------------------------------------------<br />original<br /> try to flash the damage phone with this metod:<br /> need paralel cables for two phones,<br /> WinMoDo+ ver.2.9,<br /> Gad35u.rel file,working phone and damaged <br /> phone,boot from working phone<br /> need repeat procedure 3-4 ways. <br />-------------------------------------------------<br />i have GD35 i'm using soft Winmodoflash. eraising flash from my phone and don't turn on. my phone now is dead. please help me. how make paralel cable. how repair it, please send me schematic.<br />thank you<br />regards <img src="mad.gif" border="0"> <img src="confused.gif" border="0"> <img src="eek.gif" border="0">
Old 02-25-2002, 08:40   #7 (permalink)
Member: 3041
Post
Hi man, i need to ! Mus are solution for this killed phone!???.<br />Wenn is boot into flash and is erasing, is end. After ON phone not send ignition string xXxx and what now.
One man in old forum says. You can dissasembling fyzycal flash and insert to nokia phone. After this flashing in nokia with full flash for GD35. But this mus have Fire Hot Station and maschine for work with BGA socket. Is this f*u*c*k*e*d work.
Wenn you flash this ! Then you only change IMEI and make chc in checkbox.
I dont know / no hapy !(((! <img src="eek.gif" border="0">
<br />orbiTel
Old 02-26-2002, 00:28   #8 (permalink)
Member: 3925
Thanks Meter: 22
Post
hi man <br />i can't find resolve my problem. how fix it. i'm using Pony prog. i can't reading eprom. eprom is 23xx<br />please help me<br />thank you<br />================================================= <br />regards
Old 02-28-2002, 02:23   #9 (permalink)
Member: 1408
Thanks Meter: 39
While you update flash in such weird phones as panasonic
use external power and you will haven't stupid questions anymore..
WBR
Crew
Old 02-28-2002, 21:31   #10 (permalink)
X-Shadow's Avatar
Member: 871
Thanks Meter: 602
Hello,
1. Parallel cable wont work! PC will only communicate to 1 unit
at one time.. if two, then it will have data collision and result to
bad transmission. Dead phone will not respond to PC even PC
will send command to flash.
2. Transfer IC to Nokia Phone??? What Nokia phone ? Flash
chip used by Panasonic is not standard for Nokia. Just like you
cannot remove Flash Chip from 8310 and put it in a 8210 because
flash chip now has more PINS!
3. External Power is good idea... but you must also use always
good charged battery because if battery dies during programming
boot area of Flash, then your phone is dead! In GD35 there is no
external power PIN for flashing. The external power in GD35
cables is only used for MAX232 inside the data cable because
software programmers disable PIN 8-7-4 of COM port in their
GD35 soft in the hopes that it will help lessen piracy of their soft.
How to make phone alive??? Bring to service center of Panasonic
and they will give you working phone in 1 week. Just tell them
phone was dropped inside your bath tub for a few minutes.
Or, like I said before, buy Flash Programmers that support Flash
of Panasonic GD35 and make readout from phone that is working
and write it to dead phone. You will then have cloned units.
B.R.
X-Shadow
An Idea How To Kill Of Market Killing Mx Product mbcommunication The Market Feed Back 3 02-11-2010 19:33
something wrong twister is killing or am i killing phones OKOKO Twisterflasher 4 05-06-2005 04:20
phiilips 330 killed with red-box my first phone killed with it and i hope last one loopkiller Redbox 1 11-25-2004 15:19
Already killed Philips phones? Now kill Alcatel! Xak BF, BG, TH, BHx Series 30 11-26-2002 19:53
Page generated in 0.18804 seconds with 9 queries
