Panasonic Panasonic-News... |
05-25-2003, 16:52 | #1 (permalink) |
No Life Poster Join Date: Oct 2000 Location: Split / Zagreb, Croatia Age: 53
Member: 2236 Status: Offline Thanks Meter: 58 | Any safe way of downgrade GD87... I downgraded it to version 22 and flashed language pack as well and now the phone works perfect in SMS But, now, when I enter MMS and click to check the SERVER LIST, the phone switches OFF and ON again and continue to work normal. As long as I don't touch the MMS servers list, the phone works fine... When I upgrade back to version 39, MMS server list works fine but again there are problems with SMS. Now, can't leave the phone like this. Has anyone a 100% good flash that works? Contact me by mail... Spalato |
05-26-2003, 13:09 | #4 (permalink) |
No Life Poster Join Date: Jun 2002 Location: England
Member: 13335 Status: Offline Thanks Meter: 2 | Run WinModo Software Select com port and set baud rate to 11520. Click Browse in image file, this is the firmware. Click Browse in language pack file, this is the language. Click all 3 red boxes on the right hand side. With phone turned off click start. When fisnished, run CB200 Now select the phone model and click handset power. Power on the phone and it will display Test Mode. Goto the data menu and select the settings tab. Select Function Clear (Memory Erase). When finished the phone is ready to use. to run cb2000 u may need to bridge pins 4 and 10 from left to right |
05-27-2003, 05:32 | #5 (permalink) | |
No Life Poster Join Date: May 2002 Location: TX Age: 49
Member: 12427 Status: Offline Thanks Meter: 78 | One question, when run cb2000, you meant to open the cable and connect pin4 and pin10 together? On the other forum it said to block pin4 and pin10 from connect to the phone. Which is the right way? Quote:
05-27-2003, 14:38 | #7 (permalink) |
Freak Poster Join Date: Apr 2000 Location: South Wales UK Age: 54
Member: 1169 Status: Offline Thanks Meter: 59 | posted earlier but not got a reply. could any of you guys mail be the language file for this phone as i have killed mine by just flashing soft and not language, Tx |
05-27-2003, 15:02 | #8 (permalink) | |
Member: 12427 Status: Offline Thanks Meter: 78 | Check your PM Quote:
any easy way of checking Bootloader version? | rog_gryzor | iPhone 2 / iPhone 3G / iPhone 3GS | 6 | 05-31-2009 19:30 |
Here--> The best way to downgrad the new version of the BB5s ** (With Video Files)** | aha1alfa | Nokia Base Band 5 ( BB-5 ) | 41 | 04-14-2009 00:45 |
Is there any way of getting a special code for Motorola 180? | egg | Phone Unlocking Codes & Maps | 1 | 12-01-2003 10:45 |
Any Possible Way of Unlocking 8250 v 3.12 | ed2k_7 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-07-2001 21:48 |
