Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Panasonic
Panasonic Panasonic-News...
Old 11-24-2003, 07:41   #1 (permalink)
Member: 17659
Flashing GD68, but can't power on, GD67_fixed solution can't help
Flashing GD68, but can't power on, GD67_fixed solution can't help.
Any ideas???
Old 11-24-2003, 21:24   #2 (permalink)
unlockmax's Avatar
Member: 30174
Thanks Meter: 5
Try to flash it with WinDoModo boot - main - language
Regards
Old 11-25-2003, 11:02   #3 (permalink)
Member: 17659
I did try it long time ago.
but thanks
Old 11-25-2003, 16:35   #4 (permalink)
Syed's Avatar
Member: 19979
Thanks Meter: 116
try to flash it with A33 version...
also check if u can charge the phone or not ???
and try to read the phone with CB2000, if u get IMEI Error then the eeprom of the phone is bad....
WBR
Syed
Old 11-26-2003, 01:00   #5 (permalink)
Member: 44726
I thank you seek the pack languague a33 in French
Old 11-26-2003, 07:29   #6 (permalink)
Member: 17659
your solutions not work
Old 01-26-2004, 23:23   #7 (permalink)
Member: 19764
does anybody have solution for repair eprom ? two phones say read imei fail. after changing their flahs chip (place to place).they are flashing but not power on.before change chip they was working(29 rus ver both)
Old 01-27-2004, 07:47   #8 (permalink)
Syed's Avatar
Member: 19979
Thanks Meter: 116
It does not work after changing flash chip...if u plan to swap flash IC then u got to swap the same CPU as well !!
WBR
Syed
Old 02-01-2004, 11:55   #9 (permalink)
Member: 19764
ok i have change cpu on both phone place to place so phones starts .but in one phones fault going with cpu.i need to change cpu .what can i do ,phone will no start with new cpu!!!!
Help Nokia 3310 Flash Ok But Not Power On sofiame2006 Nokia Hardware & Hardware Repair 20 01-28-2011 14:36
help nokia 3100 flash ok but not power on sofiame2006 Nokia Hardware & Hardware Repair 7 09-24-2007 18:11
help me 6600 flash ok but not power on kirpiksk Nokia Hardware & Hardware Repair 2 08-09-2006 06:12
V500 flash completed but not power on. Help fromdesert Motorola P2k 1 12-10-2005 11:30
help samsung e700 flash ok but not power on sofiame2006 Samsung Hardware Repair 0 11-11-2005 09:28
Page generated in 0.17807 seconds with 9 queries
