Panasonic Panasonic-News... |
04-05-2003, 18:46 | #1 (permalink) |
No Life Poster Join Date: Jul 2001 Location: md Age: 25
Member: 5379 Status: Offline Thanks Meter: 0 | flash gd88 with gd87, after that, crc error and dead Regards |
04-05-2003, 19:29 | #6 (permalink) |
Member: 5379 Status: Offline Thanks Meter: 0 | huh ? never done this flashing before, what boot should i press ? i already press the boot and flash again, but problem still same ... change the flash ic ? is it the big NEC chip ? what is the substitution flash ic for this phone ? are there any soft solution without changing flash ic ? |
04-06-2003, 17:10 | #9 (permalink) |
Member: 5379 Status: Offline Thanks Meter: 0 | all 3 buttons in green ? what it means ? crew : i don't know the original firmware, i still can flash the phone, how can we know the original firmware version ? by the way, i flash it with gd87a22.rel thanks for the answer regards |
04-13-2003, 03:40 | #10 (permalink) |
Junior Member Join Date: Feb 2003
Member: 21068 Status: Offline Thanks Meter: 0 | Can you plz send me the A22 file? to [email protected] |
04-13-2003, 08:13 | #11 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Bulgaria Age: 53
Member: 5579 Status: Offline Thanks Meter: 5 | Hi,Genocite.If you still can flash phone,do this:run WinMoDo,press Boot,Main and LP buttons (change their colors in GREEN) and flash phone.Must be O.K. |
08-12-2004, 01:36 | #13 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Aussie Age: 55
Member: 15355 Status: Offline Thanks Meter: 4 | if your lucky bootloader may be ok(crc error may be in main or lang) in which case reflash boot/main/lang and all will be ok if however the crc error was withing the boot area then its a case of changing flash ic or jtag. |
U900 Nand Write Error And Dead Phones Solution. | .:hack3r2k:. | FuriousGold | 38 | 06-08-2007 15:51 |
i need W810i CID 49 flash file for fix CRC error. phone dead - uncompleted unlock | PSG | SonyEricsson (USB-Smart) | 5 | 08-22-2006 21:30 |
Flashing GD87e with GD87 flash | togo | Panasonic | 6 | 08-16-2006 16:22 |
GD-96 after Gdtools crc error | artgsm1 | Panasonic | 1 | 01-14-2003 21:12 |
