Panasonic Panasonic-News... |
05-04-2001, 20:20 | #1 (permalink) |
No Life Poster Join Date: Nov 2000 Location: EGYPT Age: 44
Member: 2583 Status: Offline Sonork: 100.88702 Thanks Meter: 203 | GD52 Dead hElPppppppppppppPppppp cable go down when flashing phone before unlocking using LongDaddy Sw for Gd52 . flashing process stopped in after wrinting frame 1 .. then phone dead and i can't see the green led again using longdaddy !!! what to do ??? winmodo will work ? anything else ?!?! why LongDaddy didn't communicate again when its like winmodo ( flashing ) .. !? plz help best regards |
05-06-2001, 00:11 | #3 (permalink) |
Member: 2583 Status: Offline Sonork: 100.88702 Thanks Meter: 203 | hi There , thnx for replaying me ... i really wrote this words before reading any old posts about this .. cuz i always check any new post here in forum .. but i forgot that somtimes i ignore panasonic section ." SURE i WON'T DO IT AGAIN " ok another dead phone on my table besides the c25 v61 .. p.s : if my phone dead after getting frame 1 so its allready have bootloader in it or bootloader in the first frame but i don't think that !!! so maybe i can slove my problem when the other ppl phone stopped when erasing and after erasing .. in my case everything is DONE and phone starts to get frames .. i am stupid ? thnx v.much anwyay Best Regards |
05-06-2001, 01:10 | #4 (permalink) |
No Life Poster Join Date: Oct 2000 Location: Split / Zagreb, Croatia Age: 53
Member: 2236 Status: Offline Thanks Meter: 58 | Hi If you had started Winmodo Plus right after your accident happened, your phone would be alive now. To all: when flashing/unlocking a GD52/92, always prepare Winmodo Plus and flash files to be ready for use. Before starting, the battery MUST be full charged. Just in case if anything goes wrong so you have enough power. And dont forget: if anything goes wrong during flashing with Longdaddy soft, NEVER TAKE OUT THE BATTERY and use Winmodo Plus immedeately after it went wrong. Hope this will help in the future Spalato |
05-06-2001, 11:10 | #5 (permalink) |
Freak Poster Join Date: Jun 2000 Location: In front of pc
Member: 1585 Status: Offline Thanks Meter: 15 | hi M8! yes sometimes when unlocking panasonics, in the middle of erasing flash the sw hangs. and if you dont know what to do, surely you will have a dead phone! VERY IMPT thing to remember: DONT GET THE BATTERY OUT OF THE PHONE when something like this happen. I use for gd52 sw by Jethro cracked by Xak (100%) and sw by Skkeptik (100%). havent tried Ghost3D yet.. You can SWITCH software in the middle of the process when it hangs. Example, when using Skkeptik and in the middle of erasing or writing flash it stops, you can repeat the process..and if still the same, you use another sw to flash and unlock. But during this process DONT turn off your phone. regards to all.. |
05-06-2001, 11:50 | #6 (permalink) |
Member: 2236 Status: Offline Thanks Meter: 58 | Hi I forgot to mention that for flash/unlock of GD52/92 it is needed to work with universal interface, correct pinout and, what is most important, to have +5V connected to the phone. Than you will be 100% shure that you will unlock every GD52/92 phone you will have and that the soft will not hang in the middle of the process. This is tested on a large quantity of these phones and soft never hanged Spalato |
05-06-2001, 12:34 | #7 (permalink) |
VIP-Member Join Date: Nov 2000 Location: azaz arshad
Member: 2605 Status: Offline Thanks Meter: 0 | Hi, I saw 3 or 4 different pinouts. But I can`t test them till now.I would be helpful when I build the cable to know which pinout works with security code reader and unlocker for GD92/GD93. Please correct me if I´m wrong: I need a bridge between 1&5, 7 Rx, 8 Tx, 13 +V, 14 GND? So does it works? Thanx in advance ToTo |
05-06-2001, 18:54 | #8 (permalink) |
No Life Poster Join Date: Sep 2000 Location: MAROC
Member: 2147 Status: Offline Sonork: 63246:Paderf Thanks Meter: 20 | the pinout it s ok, i use the same pinout i unlocked many gd52 by jethro soft. verify your univirsal interface and try another time may this help you good luck Regards, |
05-09-2001, 07:34 | #10 (permalink) |
Member: 2583 Status: Offline Sonork: 100.88702 Thanks Meter: 203 | hi there , my scheme is : 1+5 short 8 tx 7 rx 14 gnd 1 - if i added %v to pin 13 maybe i can reflash phones with longdaddy ?? 2- i unlocked many phones before with this scheme so i need to add +v anyway nexttime or itsnt important in my case .!!!? best regards |
Gd52 Dead After Unlocking | OMBOSSMAN | Panasonic | 7 | 05-31-2002 20:27 |
Please help GD52 dead after unlocking. | banKa | Panasonic | 3 | 04-20-2002 21:19 |
GD52 dead after unlocking | ren777 | Panasonic | 6 | 01-21-2002 19:14 |
GD52 Dead, after unlock with battery empty | gsm flying free | Panasonic | 3 | 10-10-2001 08:45 |
gd52 dead | ryumahon | Panasonic | 2 | 09-20-2001 12:07 |
