GD55 Sim MEP Lock Failed [help please] hi. i hope this is the correct section for this question. which i first put up yesterday but unfortuneately no-one replied first hi to everyone as this is all very new to me. i have been given a gd 55 phone when it is switched on it lights up with the vodaphone logo on screen. then asks for the sim card. when i put a vodaphone sim card into thr phone and switch on i get the message [SIM MEP Lock Failed. yet when the original sim that was working with the phone is put in the phone works. i also know that the sim that is not recognised is working as it does work in a nokia 3310. am i not doing something that i should be to get the sim card recognised. please if you have a solution give me the idiots guide as to how to fix it. i am also having a problem with getting the zero button to work properly any suggestions about that would also be of great help . thanks a lot for your time guys jack54 |
Hello Jack54 i had the same problem a few weeks ago customer came to me with a 3410 on vodafone with the original vodafone sim, it would work fine but when another vodafone sim was in the phone phone displayed sim card not accepted all i did was unlocked the fone and the sim worked. i think if you unlock your gd55 the other voda sim will work, if you dont know how to unlock it, email me your imei No by pressing *#06# or lift of the battery and look their, i will instruct you.... [email protected] rgds Lee5k |
SMS me on 0026391344690 :p |
hi guys use full flash methot. good luck. mor me good work phone. regards |
Try code 53 if using 32 and 12 in order doesn't work. Andrew |
I have a GD55 and wanted to unlock it. My IMEI# 35044801-8882297. My mobile carrier is Globe Telecom from the philippines. Could anyone help me regarding this. My e-mail add is [email protected]. Thanks |
stephenv Code for NCKKN is : **00012*55729982# Code for NCKKN-2 is : **00013*74189909# Code for NSCKN is : **00022*55329182# Code for NSCKN-2 is : **00023*74385909# Code for SPCKS is : **00032*55024132# Code for SPCKS-2 is : **00033*79332909# Code for CKCCK is : **00042*55548152# Code for CKCCK-2 is : **00043*73357109# Code for PCKKP-2 is : **00052*55721902# Code for PCKKP is : **00053*76109909# |
Just use GD55 Calculator type in IMEI number , You will get the codes enter it. Bye Ravi |
Hi, I have a GD55 which displays a different IMEI than the one found in the back of the phone. Could any one help me to restore original IMEI? |
Hi.. Please help me to unlock my GD55. My phone says Sim MEP lock failed, may you help me. IMEI:35193500- 5986007 Thank You |
