Panasonic Panasonic-News... |
06-09-2004, 16:07 | #1 (permalink) |
No Life Poster Join Date: Feb 2002 Location: burning phones
Member: 9700 Status: Offline Thanks Meter: 62 | gd87 keypad problems somebody knows a solution or what is the problem? thanks in advance best regards |
06-11-2004, 18:31 | #2 (permalink) |
Member: 9700 Status: Offline Thanks Meter: 62 | tested with cb2000: when I send key commands vía cb2000, phone reply (printing keys on screen)... but keypad don't works I think is not keypad problem because phone can't receive 50% of calls... it seems other kind of problem... processor? b.r. |
08-13-2004, 11:57 | #3 (permalink) |
Junior Member Join Date: Jun 2002 Age: 50
Member: 13050 Status: Offline Thanks Meter: 0 | GD87 keypad repaired If communication with cb2000 is ok and no lock is showed on display, then your problem is hardware related. I have solved it twice: often some diodes located neer power button short and cause this problem. Check all diodes located on keypad side with tester! |
08-23-2004, 02:06 | #4 (permalink) |
Member: 9700 Status: Offline Thanks Meter: 62 | hi jvc, thanks for reply I was checked all diodes of front pcb, all seems to be ok... after reading your post I have re-checked, all ok any idea? I can't change processor (I don't have processors for gd87, I can't buy, I can't do reballing because I don't have stencils for this ultra-small balls) thecult |
09-03-2004, 20:41 | #5 (permalink) |
Member: 13050 Status: Offline Thanks Meter: 0 | GD87 keypad problems - Things to check Please check if any keypad lines are shorted to GND (only power button has one line to GND) and if flip switch is working (when you open and close the flip LCD light on and off ecc.), it is located on LCD board. If you have another GD87 you should try with another flip assembly, in order to isolate the problem, as it may also be on LCD board, external key or flex. Eventually check 13 MHz and 32 Khz clock (or change xtals, but if no change put originals back). Also try cleaning board for water damage. Let me know! |
09-28-2004, 19:41 | #7 (permalink) |
Junior Member Join Date: Sep 2004 Age: 48
Member: 80957 Status: Offline Thanks Meter: 0 | gd 87 i have a litel problem whith panasonic gd87 the telefon is workin normal but the keybad isnot workin i can torn it on and of ther is 2 locks on the display i can reciv a cals but i cant call sam one i can only call and if i take the card aut then the keys are working normaly ca can samme one help |
09-29-2004, 11:08 | #9 (permalink) |
Member: 9700 Status: Offline Thanks Meter: 62 | @jvc: at end I have changed processor (it was more easy than I was thinked), tested and changed xtal .... no solution!! I'm only waiting for other flip to test your last posibility it's very hard regards thecult |
09-29-2004, 22:08 | #12 (permalink) |
Member: 9700 Status: Offline Thanks Meter: 62 | cpu change in this phone is very easy, pcb pads are enormous and ball array is like other old ic's. First I thought that it will be more difficult because new processors have great arrays of small pads and there isn't stencils for make reballing. Now I'm waiting, when other gd87 enter in my sat I will try the flip exchange. I can't do nothing meanwhile thanks for your help best regards thecult |
09-29-2004, 22:23 | #13 (permalink) | |
Member: 9700 Status: Offline Thanks Meter: 62 | Quote:
I have checked external blue key... it have 4 points soldered to pcb, with polymeter: - When phone is off, polymeter gives continuity between two right or two left points (they are couples) but two points right don't give continuity with two points right - But when phone is on ALL POINTS GIVE CONTINUITY WITH THE OTHERS, I think it could be the problem. I have desoldered button but still same situation what do u think? | |
09-30-2004, 12:47 | #14 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Greece Age: 47
Member: 26279 Status: Offline Thanks Meter: 274 | measurment with multimeter(polymeter as you write) is not trustable all time because is using DC curent for this.some times if you have axid(from water damage) with multimeter maybe you wil measure many Kohm or Mohm resistance but the real resistance it will be a few ohm's(signal for keybord is palm's(AC) not DC). i think problem is on flex. |
09-30-2004, 21:30 | #15 (permalink) |
Member: 9700 Status: Offline Thanks Meter: 62 | ok thanks platijet, sorry for bad english very good explanation thx Then it seems to be a problem on "flip" (flex,...) but not on main pcb. Well, I now only can wait for other "flip" to try with it. Thanks again. Best Regards TheCult |
6700c keypad problem | luyanda | Nokia Hardware & Hardware Repair | 20 | 04-09-2014 10:16 |
Gd87 keypad lock code | bhavesh123 | Panasonic | 4 | 03-07-2009 15:23 |
Gd87 keypad lock | bhavesh123 | Infinity-Box | 1 | 02-21-2009 17:42 |
gd87 keypad promblems, please help | jamasterjay99 | Panasonic | 7 | 07-26-2004 14:10 |
GD87 Keypad | leosedf | Panasonic | 2 | 01-18-2004 14:46 |
